Shr-1040 need to know the rj connector pin out
Sansubg shr-1040 I would like to know the rj connector pin outt. An Armadillo ate my cable and blew out the camera. Want to replace it with a generic camera.
Thanks Joe
I found the system manual at http://dl.owneriq.net/3/369f279c-f502-4903-8918-0912f9063e94.pdf.
The manual has the layout for the cable.
Posted on Jun 21, 2009
I need the pin configuration of Battery detection cable for MGE UPS EX7RT
Here's a link to the manual.
An RJ 45 network connector will either be a crossover or a straight patch cable. http://www.mgemexico.com/pdf/EX_RT_manual.pdf
Mar 26, 2014 | MGE Computers & Internet
Samsung shr-1040
most likely you have a bad board. try resetting the unit if this works great if not then you will have to send it in to be repaired.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Apr 28, 2009 | Samsung 4 Channel Dvr
I changed the passwors of samsung shr-1040
Mode Key + CH 2
default value.
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
SAMSUNG DVR SHR 1040
I believe there is a small hole on the face of the unit. power down the unit and incert a straighten paper clip to push the reset button, power up the unit wait 30 seconds and it should reset. if that does not work get back to me.
mj
Apr 05, 2009 | Samsung 4 Channel Dvr
RS-422 connection RJ12
What I was told through the mfg. was:
pins 1,8 =NC
pins 2,7= Chassis Ground
Pin 3= TX-
Pin 4= TX+
Pin 5= RX-
Pin 6= RX+
This would actually be a RJ45 (8pin) but uses the 6 pin cable and only 4 com wires.
Evidentally there is no standard for the pin usages for serial communications with RJ connectors. So this information might not be valid for other equipment.
Jan 20, 2009 | 3Com Computers & Internet
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Dec 25, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
