Question about Canon PowerShot A630 Digital Camera
Battery cover not closing
Hi
A friend borrowed my canon powershot A360 and returned it with the battery/card cover in the lock position and wont close. The slide on top won't go to the unlock position. any suggestions?
    Sergeant:
  • 321 Answers
Worngly he inserted take it to service centre
Posted on Jun 20, 2009
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
Power wont turn on
If the camera will not power up then please check the following:
1. That the batteries are inserted correctly. Two should be facing upwards and two downwards. With the camera facing you (upside down) then the first battery on the left should have the positive terminal up, the second down, third up and last one down. If this does not work then ensure the slider switch to close the battery cover is fully closed - sometimes this sticks - as this closes a microswitch. If the camera still does not work then a fuse will have blown in the camera. This would be a very expensive repair. Hope this helps
Mar 20, 2014 | Canon PowerShot A95 Digital Camera
Powershot s3 is memory card locked
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 11, 2012 | Canon PowerShot S3 IS Digital Camera
Hi I have a Canon Powershot A530 but if I want to take photo's it says card locked?
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 21, 2011 | Canon PowerShot A530 Digital Camera
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
How do I unlock memory card on my canon powershot sd450?
Remove the SD card from your camera and look at it closely. You'll see a small switch which is used to lock the card to protect your data. You will most likely find that the switch is set to the locked position. If it isn't, slide the switch fully to the locked position and then fully back again before trying the card again in your camera.
If this fix has helped then please return the favour by rating my answer. If you still have a problem then please add a comment and I'll come back with further suggestions.
Oct 08, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Memory card is locked w. Canon Powershot SD1000
Your Sd1100 is compatible with a 4gb card, so that's not the issue. If the lock-switch is in the correct position, the only logical conclusion (which you have already come to.....good troubleshooting on your part!) is that the camera is busted. Send your two "friends" the bill. What a drag.
May 27, 2009 | Canon PowerShot SD1000 Digital Camera
Hi. My Canon Powershot sd400 is telling me there is a " memory card error"...and "Card Locked!". Any idea how to fix this? Heidi
Hi!
You have to unlock your memory card. All memory cards have this small lock mechanism on the side.
Make sure that the slider is on the UNLOCK position. If it's already on the UNLOCK position and you are still getting the same error message, try to set it to LOCK, then set it back to UNLOCK position.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
The memory card slot is not accepting the memory card
CHECK TO SEE IF THE SMALL PROTECT TAB SWITCH HAS BEEN CLOSED ON THE CARD. IT'S JUST BELOW THE TOP EDGE. IF THIS DOESN'T WORK BORROW A FRIENDS CARD AND SEE IF IT WILL CLICK INTO THE SLOT. OK? IF YOU NEED MORE HELP, REPLY TO: ARCLIGHT1217.
Nov 16, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A630 Digital Camera Logo
104 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
