Question about GE Spacemaker JVM1640SJ Microwave Oven
Stops cooking Cooks for about 2 seconds and message comes on to reset clock.After resetting clock, same thing happens again.
  • 9 more comments
  • vitamum Nov 03, 2007
    Is a magnatron thermostat easy to replace, or do I need to call a serviceman?
    When I finally got a "live" person on the GE service line after going through a ton of prompts, they could only tell me there was a problem with the control panel and a service call would be $89 which would be credited back to the labor and part cost. No estimate of final cost.
    Thanks much--the answer was a great help.
  • Scharf Nov 03, 2007
    Intermittent power outages. Cooks for a couple seconds, stops, then have to reset clock and date.
  • zeep Nov 05, 2007
    microwave shuts off and clock must be reset to resume cooking. Sometimes it cannot be reset and you must wait until it displays message to set clock. Now it does not turn on or display message at all. Only 16 months old. GE customer relations representative said,"Oh well. Some appliances fail sooner rather than later." My next appliance will NOT be a GE. What lousy concern for a reliable product for supposedly valued customers.
    I think GE knows this is a defective product - this model JVM1650 is no longer being made. By the time a recall is announced - consumers will have long ago replaced their microwave with something else.
  • vitamum Nov 14, 2007
    Your suggestion worked!!
    I don't have the film yet, but I placed a small plastic cutting board behind the control panel and started the microwave. It didn't stop cooking.
    Is there any special way to attach the film? I want to be safe & not creat any other problems.
    Thanks again.
  • Anonymous Nov 20, 2007
    Same problem, cooks for a couple of seconds and then shuts down, reset clock & date, etc. Like the earlier comment, how do you attach the film to safely solve the problem?
  • vitamum Dec 01, 2007
    I have yet to find the static guard film & have been to 3 shipping stores and called a couple of computer stores. One had a plactic bag that said static guard, but it wasn't the silver lined one and didn't work. I still have the plastic cutting board sitting behind the control board but can't close the control panel.
    Any other thoughts as to where I can find the static guard sleeve or film?
    Thanks much.
  • nemo45 Dec 26, 2007
    I am having the same problem! Our Adora GE microwave will interminttently shut off after 2 seconds and respond with the message to reset the clock. Sometimes it lets us reset and other times I have tried unplugging it (which works). I hate the idea of having to take it apart ourself.
  • tarheel1 Dec 27, 2007
    ge spacemaker cooks for 2 seconds and loses power. must reset clock and then the same thing happens over and over.
  • helpdadout Jan 05, 2008
    I have this same problem with my microwave, same model. How do I put this film or plastic to correct this. I have five children so you know I need the microwave.
  • Faysie Jan 07, 2008
    Same exact problem. I'm wondering about this film you're putting behind
    the control panel. Can you explain in more detail??? This is very
    frustrating and we are about ready to scrap and buy new microwave. This
    GE is only a couple of years old and has been shutting down for most of
    the time.
    Thanks for any info
    mgwarr
  • no_fan_of_ge Jan 25, 2008
    I had the same problem, but seem to have fixed it last week. Thank goodness, because with 2 little kids, I really need the microwave.
    My January '05 model JVM1653 would intermittently have a flickering display then reset itself after about 3 seconds into a full power heating cycle (it was still ok on reduced power). I don't know what the problem was for sure, but protecting the front panel circuit board from radiation seemed to do the trick.
    I put a sheet of aluminum foil in a ziplok bag (I used the gallon size, but the 1 qt size would probably do just fine), taped a "twistum" tie with the plastic stripped off the ends of the wire to one corner of the aluminum sheet, and then sealed up the bag and put a piece of tape on the corner of the bag where the wire was hanging out. With the front panel tilted out, I attached the other bare end of the tie to the green ground wire screw. I then "stuffed the ziploc into the open behind the panel while trying to keep the circuit board as shielded as possible. I carefully closed up the front panel, making sure i didn't get the ziplok punctured by the circuit board stuff.
    So far so good!!!
So far so good!!!
Posted on Jan 28, 2008
I just taped in a static bag and that solved it immediately! Great advice, and cheap too! It only takes 3 screws to open the control panel. First take off the top front plastic grill, then the 1 ***** above the screen. slide the screen panel upward and it will hinge open. You can see the magnetron behind the fan inside. No wonder the radiation is messing up the circuit board. I can't believe they didn't shield it already!
I only wonder how much of that radiation is leaking out into my head. I guess when my brain starts heating up it's time to get a new microwave!
Posted on Mar 10, 2008
Got our unit back from the repair center a couple days ago. I spoke with one of the repairmen who told me this microwave made in Korea is used by several different companies and that he hasn't heard of it having any major problems. He said GE is replacing the magnatron with a different one that fixes the problem we're all having. He said all magnatrons leak RF. We're just happy to get our microwave back and it cost us $50...much cheaper than the $185 a certified GE repairman was going to charge us.
I'd recommend having GE send you the magnatron and diode and take it to a repairman yourself.
Good luck all.
Posted on Jan 03, 2008
Same problem here with the same GE Spacemaker microwave. Mine's been out since 12/06/07. GE shipped me a new magnatron and diode. The problem is the GE serviceman wanted to charge $185 to repair...HA. I took it today to another repair shop who is suppose to repair it for $50. I'll try to call them tomorrow to tell them to place this film in there while they are repairing it.
My experience with GE like you guys has been horrible. The GE cares number is a joke. The GE consumer affairs number 800-386-1215 is just as much a joke.
Never again will my money go to GE. I've searched for a good microwave and it seems they're all junk these days...good ole crap from China. It's sad our country's businesses have become such a sell out.
Good luck guys.
Posted on Dec 19, 2007
I had the same problem on my GE microwave. I installed some static paper and it seems to have fixed the problem. Thanks for the tip
Posted on Dec 09, 2007
Same problem solved using the static film that computer parts are shipped in..sort silver like..there is rf leakage from the magnetron and by creating a barrier between the circuit board and the mag, you eliminate the problem...local computer repair shops,often have these laying around(static film sleeves) works like a charm.cut to fit and you are ready to go,
Posted on Nov 13, 2007
  • fixit60 Nov 29, 2007
    Regarding attaching the static film to the circuit board..any non conductive tape will do....there is an expected life span of about one year for using the static paper..One sheet of it will cover several years so it no big problem..
    Regarding fixing the static film to the circuit board...you can lay it in there or attach with any non conductive tape...also the fix will last about a year,but i had plenty of film left over for future applications..I installed the film over a month ago and all is well...
    Problem Solver:
  • 10 Answers
Magnatron thermostst defective .
Posted on Nov 03, 2007
SOURCE:
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Amana RC22S2 Cooks but not as well as before. Continually shows Call SERV
It is sensing the unit is not heating properly and telling you to call for service. Resetting will only delay it from showing the error alert again. It has a current sensor on the unit to tell if it is running properly, if not, it gives the error to let you know it is time for repair.
Oct 12, 2017 | Microwave Ovens
Buttons aren't working. It says Press Start and when you do it either doesn't work or add second to the cook time, and never cooks
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still does not work, you likely have a failed membrane keypad.
We would need your full model number to help you further or give an estimate.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Aug 18, 2010 | GE Microwave Ovens
My panasonic inverter microwave model no NN-T523M switchs off after 5 secondsno matter what setting. the digital screen says consult manual, which has been misplaced
You can find Panasonic owner's manuals here.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 7 seconds, it has a problem with the inverter.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you decide to replace your inverter, you can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
May 15, 2010 | Panasonic Microwave Ovens
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Microwave works for 30 seconds and then turns off
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 23, 2008 | Microwave Ovens
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Jul 26, 2007 | GE JVM1860 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
2,041 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
