Question about Dyson DC18 all floors Bagless Upright Cyclonic Vacuum
Decreased wand suction
The hose is clear yet when you take the wand out, there is no suction
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 83 Answers
The blockage could be in the wand itself or in the entry duct of the machine. Take the wand off, look through it and if you can't see light coming through the other end, there is something stuck in the wand - take it out with a long object like a metal hanger...if the wand is clear, call the Dyson helpline - they will do a thorough blockage troubleshoot over the phone and clear the blockage.
Posted on Jul 30, 2009
  • dysonrfb Dec 10, 2010
    Check if the valve at the base of the wand (where flex hose attaches to vacuum body) is open or shut. It is supposed to rotate for either floor or wand when needed. If it is shut, the plastic assembly is most likely broken and will need to be removed and replaced. Not sure if the DIY'er can do it or have to take it to dyson repair.
Wertheim x3000 motor running but little suction?
Check all of the filters. When there's extra heat, it's usually blocked filters.
If not, dismantle the wand and use long pipe cleaners or a bottle brush to clear any possible jams in the wand or head. Remove the hose from the main unit and if possible, drop ball bearings or marbles down the hose to try and clear any blockage. Remember to recover all of the ball bearings or marbles before you reassemble the hose and wand.
Aug 13, 2014 | Vacuums
No suction from canister on electrolux guardian model c154e. green light on switch is on
Have you remove the hose and checked the suction at the intake of the vacuum? If the motor is running there will be suction.
If there's suction here, attach the hose to the vacuum, turn it on, and check the end of the hose for suction. If there is none or very little, there's a clog or bad leak in the hose. The easiest way to check for a clog is to drop a coin in one end, lift that end up allowing the coin to drop through to the other end and out. If it drops through, the hose is clear. If not, the easiest way to clear it is to plug the hose in to the exhaust port of the vacuum, place the other end into a large garbage bag or point it outside, and turn on the vacuum. This will usually clear a blockage.
Leaks that are severe enough to result in no suction will be readily apparent as tears, cracks, or cuts in the hose. A crushed hose will also result in the loss of suction.
If suction is fine at the end of the hose, do a visual check of the wands. It's unusual for them to be blocked, but not impossible.
Check the power nozzle above and behind the brush and where it attaches to the wand. The elbow can catch long objects resulting in a blockage.
If there don't appear to be any problems with the above mentioned items, you need to take the vacuum, with attachments, to a repair shop to have it checked. It may need a new motor, but that would be due to worn out or broken fans, and that is unlikely with Electrolux vacuum motors years older than that.
Dec 01, 2013 | Electrolux Guardian Bagged Canister Vacuum
My Electrolux guardian C135 vac has lost suction. replacing the bag does nothing. removing the HEPA filter has no effect - what do you suggest? Will a replacement HEPA filter make any significant...
No you have a clog in the hose, wand or at the power head. Remove the hose wand and power head from the the vacuum. Turn on the vacuum, put the palm of your hand over the hole in front, you should feel plunty of suction. Then replace just the hose and put the palm of your hand over the end of the hose. If you do not have suction the clog is in the hose. You can try putting the hose on the blower port to blow out the clog or use the wire from a coat hanger. If you have suction, then add just the wand and repeat. If you have suction, then the clog is in the neck of power head, you will have to use a coat hanger to clear it.
May 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
My Dyson dc 18 slim extender wand has NO suction. There is a plastic white cylinder object blocking.
If the floor head has suction and the wand does not, or vice-versa, the white cylinder you are referring to diverts the suction between the floor head and wand. If the flimsy plastic switch used to turn the cylinder is broken, you may need a new under carriage or just set the cylinder to wand or floor manually and use it as a one dimension cleaner. Depending on your ability, perhaps the switch can be purchases and replaced by a DIYer, but the job looks moderately difficult.
Jan 31, 2010 | Dyson DC18 Allergy Bagless Upright Vacuum
A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I just bought a used Dyson DC07. Works good but
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction - Infinity Shark Vacuum NV31C
You might try sucking the sose out with another vacum from the wrong way. You might be able to remove the hose and push a broom handle or stiff wire through. If you have compressed air available, you could try that, outside.
Im sure you have a clog and if you remove it, you will be back in business.
Thanks for your interest in FizYa.com
Dec 11, 2009 | Euro-Pro NV31 Infinity Vacuum
My DC17 hose has no suction and is constricting
You have a blockage in the wand - take the wand off of the back of the machine, separate the wand from the hose by pushing the red button where the hose is attached to the wand. Hold the wand up in the air and look trough it. If you don't see light coming through the other end you have a blockage in the wand. Take a long object like a stick or a metal hanger and remove the blockage. I am confident that this is where the blockage is but...if you can see through the wand the blockage is in the u-bend, but the hose won't constrict then...remove the u-bend which is attached to the vac at the bottom next to the long gray hose - it is attached to the machine with a plastic screw - turn the plastic screw 45 degrees anti-clockwise and clear the blockage from the u-bend.
Jul 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC18 all floors Bagless Upright Cyclonic Vacuum Logo
1,057 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
