Question about Microsoft Xbox 360 Elite Console
I have the same problem
My friend recently hit my power switch in my room and gave my xbox red rings but i fixed it because the power supply was red. But my xbox has been turning off and freezing at the xbox 360 starting screen. My bro has a xbox so i use his power supply but have been getting the same problem. And now my tv has no signal on my xbox channel and it wont get my xbox controller signal
    Genius:
  • 1,093 Answers
The reason that the freezing happens is because the soldering snaps off the GPU and the CPU and when they cannot communicate you get this problem.
You will either need to send it in for repairs about a 2 week wait till you get it back or repair it yourself
Posted on Sep 03, 2009
  • 142 Answers
Something with the motherboard must be malfunctioning. You probably need to have ur console repaired so call microsoft at 18004myxbox
Posted on Jun 21, 2009
My xbox ac adapter keeps indicating an orange light when it is switched on without connecting it to the console. When I plug it into the console and then switch the xbox 360 console on, the console gives...
Disconnect everything and reconnect it,if that doesn't work, try to hook it up in a different room. If you are still having problems, you need to contact customer support and may have to order a new power supply cord.
Sep 17, 2011 | Microsoft Xbox 360 Console
What my problem is that I turn on my xbox360 and it lights up green and put the channel its usually on the TV and then just says no supporting format when I have my wires for the xbox plugged in. And i...
The red rings can also mean that your xbox is not receiving proper power from the power supply. make sure all the cables are properly plugged in. Turn off the console, unplug everything, then plug it all back in, and then restart your xbox this should fix your problem, or else your xbox is malfunctioning.
May 28, 2011 | Microsoft Xbox 360 Console
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
I finished fixing the red rings and my 360 was working fine but it doesnt turnm on now. WHY?
Is your power supply getting power (ie. is the light yellow). When you hit the switch on the (XBOX), does the power supply turn light turn green? If not, the XBOX is not recognizing the switch or the power supply is bad.. If it is, then you may want to recheck your red rings fix. The parts you've installed may have come loose and shorted something out.
If your trying to turn the XBOX on with a joystick, you may have to resync them. Try using the XBOX switch on. If it turns on with the XBOX switch and not the joysticks, it could be the wireless component in the XBOX or the joystick batteries.
**NOTE: I am saying XBOX but I mean the 360.
Nov 02, 2009 | Microsoft Xbox 360 Console
MY Power Supply light is blinking orange and xbox 360 want turn on
I hate it when people put "Red ring of Death" for a ORANGE flashing light on the power bar and actually a red ring on the front of the Xbox (which then would mean the red ring of death)!
I just fixed this problem for a friend. They had a contoller charging lead plugged in to the front which had a bad connection in it. Thats all it was so I just unplugged the charging lead and it worked.
So Unplug everything except the power and see if it works 1st, if it does then plug things back in one by one and see when it starts to flash and thats your problem lead there.
Aug 04, 2009 | Microsoft Xbox 360 Elite Console
Xbox works can't see or hear on tv
What type of output cable do you have? The older models (before HDMI) had a switch between composite and component output (this is on the output cable itself). If yours has this try switching over and plug in using another method. If this works i'd try a friends cable and see if that fixes your problem.
Jan 13, 2009 | Microsoft Xbox 360 Console
Xbox problem
A friend of mine recently experienced that same problem he just called 1-800-4MY-Xbox and they gave him a button combination to press on his Xbox 360 controller and it reset his system and fixed the problem
Nov 22, 2008 | Microsoft Xbox 360 Console
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
65 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
