Question about Kenmore Elite Oasis 27052 Top Load Washer
Belt slipped off machine
My belt slipped off my washing machine and i am not sure how to put it back on. the machine fills up with water but it wont agitate
    Sergeant:
  • 212 Answers
Rotate pulleys while trying to reinstall belt. if belt slipped off on its own then belt is streched out. replace belt
Posted on Jun 20, 2009
Machine filled but wont cycle
Is the motor running, but the machine not washing? Does the timer advance while its not washing? If the first, look underneath it if the belt could be slipping or broken. If the time does not advance make sure it has adequate power to the unit.
Jul 30, 2014 | Roper Washing Machines
Water wont go into the machine but the wash light comes on here a clink but dosent fill with water an start cycle help plz
IF YOU ARE SURE THE WATER SUPPLY IS ON. SHUT OFF WATER TO MACHINE AND REMOVE HOSES ON BACK OF MACHINE AND CK SCREEN ON VALVE THEY CAN BECOME PLUGED AND WILL BLOCK WATER FLOW. PUT THE HOSES IN A BUCKET AND TURN ON JUST TO BE SURE IT IS NOT ANOTHER PLUMBING PROBLEM.
Apr 21, 2014 | Indesit WA 115 Front Load Washer
I put a load of wash in the washer filled with
im guessing this is a performa? if so you may have something cought in your pump. remove the obstruction and check to make sure the pump is free, then replace the belt. the belt should seem a little loose as it needs to slip to get the machine up to speed in the spin
Feb 07, 2010 | Washing Machines
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
Bosch classixx 1200 wont spin at all, water fills ok even pump to drain it back out .can hear it clicking as it tries to get motor to turn
You need to check the back of the unit and there's a strong possibility that the belt is broken or slipped out of track.
Jun 26, 2009 | Washing Machines
My 2 year old machine does not fill, the spin cycle souds like it is spinning, but the drum stayes stationary. The adigator works
check make shore the water is not turned off at the back pipes , see if the belt is slipping , remove the top and put it on spin then look see if the belt on the moter is going round
Jun 24, 2009 | Washing Machines
Spin function on washing machine not working
Take the back off of it. Has the belt slipped off? Are you getting water to fill the tub? Need more info.
May 21, 2009 | Washing Machines
Washing machine quits after filling
I believe you need a new belt. The weight of the water is to much for a loose belt that is connected to the agitator.
2. Make sure nothing is blocking the safety shut off located on the machine.
Jan 19, 2009 | Washing Machines
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
274 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
