Question about Brother HL 5250DN Laser Printer
Brother 5250DN printer noise
I just put in the first new cartridge since I bought the printer. Now when it prints, the printer makes a noise.
  • 2 more comments
  • Anonymous Feb 17, 2008
    a load, clacking sound, about 1/2 sec apart when feeding paper, either tray. seems to be coming from back of printer
  • Jukikee May 15, 2008
    I have the same problem but it sounds like it comes from the paper tray. I took out the cartridge and put it back in, no change. Pulled out the paper tray and put it back in. No change. Any other ideas?  There are three loud clicking sounds about 1 second apart.
  • gerame Jun 04, 2008
    When I load my printer with paper it makes the same clacking noise after thorough investigation I found that the gear on the left side of the paper tray is slipping when it is trying to lift the tray to feed the paper.
    Is there any way to fix this?
  • wineswami Jun 25, 2008
    This is my second HL-5250DN, and both of them have this exact same problem.  On the first machine the problem eventually went away.
  • 3 Answers
Check my solution here:
Here's a solution for you with Brother HL 5250 D/DN/DNT
Change the paper setting tab in the tray to make sure you have a small gap between the top part of the paper and the bottom part.
so if this is the old settings : |paper| --> you want to make it: | paper| so you can have slide the paper back and forth.
DON'T adjust the setting to the next paper size because the roller wont catch the paper if it slide too far.
Good luck to all.
Posted on Oct 22, 2008
The only thing to do is reduce the amount of paper in the tray. :(
Posted on Jul 23, 2008
  • 3,587 Answers
Sounds like cartridge may not be seated firmly..check that first
check here for fresh set of printer drivers
Posted on Mar 02, 2008
2 Suggested Answers
  • 114 Answers
SOURCE: Brother HL-5250DN Laser Printer making noises and not printing
some gears are not in proper position , pull out the paper tray and closed it strongly .
Posted on Jul 18, 2010
CP3525X printer will not print the black cartridge.
Your ink cartridge is low, empty or possibly clogged
First step is to see will if it print a test page
Go to Start, settings, printers. Right click on the printer, properties, print test page.
If that doesn't work there should be a head cleaning option in properties that will make it clean the print heads.
If there is still nothing after that then either it's badly clogged, low or out of ink, and needs to be replaced
This may help
Turn on the hot water until warm
Put about 1/2 inches of water in a cup
Put the print head portion (where the ink comes out) in for about a minute or two
This will help to dissolve the clogged print head
Dry off the cartridge using a soft tissue.
Re-insert the cartridge into the printer.
Run the normal cleaning software routine a few times
Still having Problem Then follow Us For
Brother Printer Support
Feb 21, 2014 | Brother HL 5250DN Laser Printer
HL-5250DN Laser Printer: We have a brother 5250 laser printer. Trying to...
The problem coming because there is some paper jam in side the printer. Remove the toner cartridge and look inside the printer for any paper jam.
I hope it will help to solve your printer problem.
May 18, 2010 | Brother HL 5250DN Laser Printer
Nov 17, 2009 | Brother HL 5250DN Laser Printer
My Brother 5250DN is not pulling paper through. What could it be?
do a test print... see you manual. You hold a button for 3 seonds and it'll print a test page. If that works you should be OK. Make sure that your paper tray is NOT over loaded. Maybe try less paper. Try the manual feed using one sheet of paper
Oct 27, 2009 | Brother HL 5250DN Laser Printer
Drum and error light are on - got new cartridge - installed as directed - blue light will not stay on - printer will not print - red and orange lights will not go out
I can't recall the buttons on Brother laser printers but leaving the cartridge door open and pressing and holding down one of the buttons for about 5 seconds will clear the drum light error.
I've done this to clear the same error on aBrother HL5250DN laser printer.
If this doesn't work please post your printer's model number.
Sep 21, 2009 | Brother HL 5250DN Laser Printer
Brother 5250dn internet connection problem
your ip settings is getting blocked due to printer settings.just uninstall the printer driver and reinstall the drivers again. this will make new settings.
Mar 05, 2009 | Brother HL 5250DN Laser Printer
Toner light still on with new toner
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge2_bing.gif to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Feb 11, 2009 | Brother HL 5250DN Laser Printer
Will not print
Although the toner cartridge we used was listed as compatible it was a universal cartridge and when replaced with a Brother cartridge the machine began printing and the error indicator light went back to normal. All is well.
Oct 14, 2008 | Brother HL 5250DN Laser Printer
Brother HL-5250DN
call brother and tell them that the drum is shadowing and needs to be replaced or you can look in your area for a cartridge World and pay them to remanufacture that drum and If you are going to be printing check you really need to find a printer that has micr toner it has more metal ion the toner which makes it burn hotter.The toner that you are using may possibly be able to be lifted and info on the check could be
Jan 12, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
750 people viewed this question
James Cagle
James Cagle
Jim Keysor
