Question about Maytag Atlantis MAV6000 Top Load Washer
Leaking from bottom.
I have a leak. I have opened it up and cannot see water coming from the top of the water pump, but it is wet inside. When I turned the washer on water is coming out of the bottom.
    President:
  • 1,185 Answers
Either the door gasket has split or the delivery hose to the pump
In both cases if you cannot tackle the work yourself you will need to get a repairman in
Posted on Jun 20, 2009
Washing machine top load leaking water bottom model # LXR7244JQ1
The pump is near the front, bottom of the machine. You need to unplug and unhook it from the water supply. Then get a wet and dry vacuum and remove all the water from the machine by using the vacuum on the drain hose. Then you can lay the machine down to get to the bottom of it and you can replace the pump. http://www.partselect.com/ModelSections.aspx?ModelID=709279&ModelNum=LXR7244JQ1&mfgModelNum=&ManufactureID=3&Selected=TVCOCCCE&Position=6&mfg=Whirlpool&Type=Washer&Mark=4
Jul 10, 2014 | LG WM-2277HW Front Load Washer
I have a 1999 land rover a4.0 i have a coolent leak in the water pump area it dosent look the water pump is leaking
Confirm that the leak is not from the pump.. With the engine cold and off, clean all surfaces which are wet. Make sure the top of the engine is not wet as well. Start engine and look for where the leak is using a flashlight. Be careful of moving parts.
Water pumps have weep holes that leak when the pump bearing is faulty, small holes on the top/bottom of the pump. Also look for leaks from the hose connected to the pump.
May 06, 2014 | 1999 Land Rover Discovery
Looks like a leak at the bottom of engine
It is likely the water pump is leaking and the coolant is running back under the engine. Put you finger under the bottom of the water pump near the front where the shaft comes out, if it comes back wet with coolant the pump is leaking.
Oct 10, 2012 | 1998 GMC Sierra
Water leaked out from under washer while it was running. No leaks visible from hose connections at hose bibs, nor where water supply lines (hot and cold) thread on to the top right at the back. No leaks...
I would open the door and puled up the bottom. Part were that fan twister spins on the bottom.. and check that the ida filler is not gonskie or may be blokidge right there So water would v come out. And clean it all there. It prolly never been done ????. Hope that helps ?? Tony
Apr 19, 2017 | Kenmore 24732 Top Load Washer
Water is leaking and we change the water pump
A thorough visual inspection of all cooling system components is necessary to find the leak. Check all coolant hoses and pipes, check the radiator in particular where the hoses connect (top and bottom), feel the carpet on the passenger side front floor, if it's wet then your heater core is leaking. Also you mentioned replacing the water pump check there the gasket may not have sealed and could be leaking around the flange. Hope this helps.
Please rate my advise.
Jan 14, 2011 | 1995 Oldsmobile Silhouette
WATER IS LEAKING FROM THE BOTTOM. IT'S COMING FROM FROM THE PUMP.
This is repaired by pulling the unit out and working from the rear and underneath, check for the leak, either replace the pump or gasket or hose, depending on where the leak is coming from. You may need some star screwdriver type tool.
Mar 24, 2010 | Maytag MDB7100AWB Dishwasher
January 31, 2010 Kenmore top loading series 80 leaking from bottom toward front. It started during a wash cycle. I put two wet towels back into the empty washer and put on spin, leaking reoccurred. ...
is the pump leaking?or you could have bad tub seals,follow the center trany shaft up to the tub and see if it leaks there,is it noisy when spinning,you gotta just get in there with a light and look around to see where the water is coming from,if you sent pictures they didn't show up,remove the front cover,take out the two screws that hold the console down,remove the two clips with a screw driver and unplug the lid switch wires and pull the cover back and remove it
Jan 31, 2010 | Washing Machines
IT IS LEAKING WATER FROM THE BOTTOM OF THE ENGINE.HAVE REPLACED TOP RADIATOR HOSE BUT CAN'T STOP LEAK
Hello.
Check to see if your water pump is leaking, there is nothing else on the motor that can leak coolant. Check the radiator core also. You can check that by looking at the bottom of the radiator and seeing of its wet. If so, check the sides of the fins, the core will go if the radiator is pretty old and if the truck has been sitting for quite a while. If your getting no leak there, its probably your water pump. Just run your finger around and see if there is any wetness. If that also is not where the leak is, check the water neck. Its where the top radiator hose connects to the top of the intake at. That may be it too. Coolant can run down the motor and fool you of where it actually is leaking from. There is only one more place that you can check other then the ones I I have stated, check the bottom of the heads just below the valve covers and check there.
Hope that helps!
Dec 06, 2009 | 1990 Ford F150
Leaking from the kenmore washing machine
Any part of the machine that has water contact is a possible source of the leak. Look for the highest (elevation) wet spot--that will be close. The tub has a couple of rubber connections--one on the side for water level sense and another for water drain on the bottom. If the tub itself has a rusted out spot, it can be repaired with epoxy cement (from inside the tub). It will be necessary to remove the inner tub assembly to get to the outer tub.
Jul 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GWL11 Washer. Leaking from bottom. Doesn't appear to leak during wash cycle.
Have you checked the pump on the bottom of the washer? You may have to empty the water out of the unit by hand. Then tilt the machine backward. The pump is on the bottom and no tools are needed to remove it. If the pump is wet or rusted then that should be your problem. Another way to check the pump is to remove the 2 screw ib the back of the machine on the top, and remove the electronic controlls. inside the machine is instructions to turn the pump on.
Jun 18, 2009 | Fisher and Paykel GWL11 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
