Question about Acer Aspire 5735 Notebook
Very slow start up
Very very slow start up . Some problems with system event log.
    Sergeant:
  • 321 Answers
Unistall useless programme delete temp files & folder, delete temp internet files, dont save big files on desktop
Posted on Jun 20, 2009
In dg41wv server 2003 is not loading
problems in Windows Server 2003
To start the computer by using Last Known Good Configuration, follow these steps:
Click Start, and then click Shut Down.
Click Restart, and then click OK.
When you see the message Please select the operating system to start, press the F8 key.
Use the arrow keys to select Last Known Good Configuration, and then press Enter.
Collapse this imageExpand this image
Note NUM LOCK must be off before the arrow keys on the numeric keypad will function.
If you are running other operating systems on the computer, click Microsoft Windows Server 2003 on the list, and then press Enter.
Notes
By selecting Last Known Good Configuration, you can recover from problems such as a newly added driver that may be incorrect for your hardware.
This feature does not solve problems caused by corrupted or missing drivers or files.
When you select Last Known Good Configuration, only the information in the following registry key is restored:
HKLM\System\CurrentControlSet
Any changes that you have made in other registry keys remain.
If you can start your computer by using the Last Known Good Configuration feature, the last change that you made to the computer (for example, the installation of a driver) may be the cause of the incorrect startup behavior.
if this fails to fix the problem try to repair in safe mode
How to start the computer in safe mode
When you start the computer in safe mode, Windows loads only the drivers and computer services that you need.
You can use safe mode when you have to identify and resolve problems that are caused by faulty drivers, programs, or services that start automatically.
If the computer starts successfully in safe mode but it does not start in normal mode, the computer may have a conflict with the hardware settings or the resources. There may be incompatibilities with programs, services, or drivers, or there may be registry damage. In safe mode, you can disable or remove a program, service, or device driver that may prevent the computer from starting correctly.
To troubleshoot startup problems in safe mode, follow these steps:
When you see the message Please select the operating system to start, press F8.
On the Windows Advanced Option Menu, use the arrow keys to select Safe Mode, and then press Enter.
Note Num Lock must be off before the arrow keys on the numeric keypad will function.
Do one of the following:
If the computer does not start in safe mode, try starting the computer by using the Recovery Console. If you still cannot start the computer, look for possible hardware problems, such as defective devices, installation problems, cabling problems, or connector problems. Remove any hardware that was added recently, and then restart the computer to see if the problem is resolved.
If the computer starts in safe mode, go to the next section to continue to troubleshoot the startup issue.
Use Event Viewer to identify the cause of the startup problem
View the event logs in Event Viewer for information that can help you identify and diagnose the cause of the startup problem.
To view events that are recorded in the event logs, follow these steps
Click Start, point to Administrative Tools, and then click Event Viewer.
Start the Event Viewer snap-in in Microsoft Management Console (MMC).
In the console tree, expand Event Viewer, and then click the log that you want to view. For example, click System log or Application log.
In the details pane, double-click the event that you want to view.
To copy the details of the event, click Copy, open a new document in the program in which you want to paste the event (for example, Microsoft Word), and then click Paste on the Edit menu.
To view the description of the previous event or the next event, press the UP ARROW key or the DOWN ARROW key.
Use this tool to help identify possible problem devices and device conflicts.
To do this, follow these steps.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
you might be able work your way through the problem
hope this helps
Sep 01, 2012 | INTEL - MOTHERBOARDS Dg41wv Uatx Intel Gma...
Windows cannot connect to system event manager
If this problem has not existed for very long try doing a System Restore to a time prior to it starting.
Do you have more than one user profile on your system, if so, have you tried logging in with a different profile to see if the problem exists globaly or just in your normal profile? If the problem is with your profile only then this would suggest that the profile is corrupt and you should create a new profile if you don't have another already.
Another option is to run the System File Checker utility to determine if you have any corrupted or missing critical Windows files.
Lastly try temporarily disabling your AntiVirus and Firewall software then try to access the Event Viewer management console - it is probably best to have your computer disconnected from any internet access when doing this. If this succeeds then check for any events related to the error in opening the Event Viewer - you may find it easier to clear all the current events first then recreate the error and look at the logs again to identify the most current and relevant entries.
Dec 29, 2011 | Microsoft Windows 7 Home Premium 64BIT...
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Sep 23, 2009 | Adobe Photoshop 6.0 for PC
Fujitsu siemens an unexpected I/O error has occured
Hello olamideidowu,
Here is a way to find out what the message means. Look for entries in the system event log that happened on the same day your error message happened.
*Using the Event Viewer:
•Click the Start button on lower left corner of the screen
•Select 'Run' (on Windows XP) or Type 'Run' and press the Enter key (on Windows Vista)
•Type 'Eventvwr' (in the 'Run' box) and click OK.
•(On Windows Vista) open the Windows Logs folder in the left pane
•Select the 'System' log in the left pane
•Look at the system events that happened on the same day as the I/O error. One (or more) of those events should contain the 'unexpected I/O error' message.
•Get the Event ID and look up what it means on the Microsoft Events and Errors Message Center: http://www.microsoft.com/technet/support/ee/ee_advanced.aspx
Also, the 'Message Level' of the event shows as Information, Warning, Error or Critical. Looking at the message level can help determine how serious the event may be. Events that have Error or Critical message levels can indicate a problem on the system.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 05, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
SUMP error in Windows Vista
Try to increase the size of Event Logs files.
Open up Event Viewer by typing in eventvwr into the Start \ Run box, or you can find it under Administrative tools section of Control Panel.
You’ll notice over on the right-hand side of the window that the current size of my Application and System Event Logs are 512 KB…
Now you can right-click on one of the Event Logs in the list, and choose Properties from the menu.
In this dialog you can do a number of things… you could clear the log, increase the size, or just set the system to overwrite events as needed
chose to increase the maximum size of the event log, and then also to overwrite events as needed
For those of you using Windows Vista, you’ll notice that the default settings in Vista are to overwrite as needed, and the maximum size is way bigger. Guess my setting choices make sense then…
Aug 04, 2009 | Microsoft Windows Vista Home Premium SP1...
Windows event log service wont start, error code 5
Your right its not a virus, and its not because your running one of the top anti- virus software,the problem is else where.
Have you checked the log files to see if you have permission?????
Have you checked event viewer to see if you have permission????
I need to know or the fix I have for you will not work.
Mar 13, 2009 | Dell Inspiron 530 Desktop Computer
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
All the games run slowly even low graphiced games. even i have dx 10, 1.8ghz processor , 1290 mb of ram and no viruses.? they just run in slow motion
A FEW THING TO DO DEFRAG THE DRIVE MORE THAN YOU ARE DOING NOW, IF YOU DO ONCE A MONTH YOU MAY MAY WANT TO DO IT 1 TIME WEEK.
IN YOUR COMPUTER IS A SECTION IS FOR PERFORMACNE ENHANCEMENTS, OR IMPROVING SYSTEM CHECK AND OPERATIONAL ERRORS AND LOGS, THESE LOGS ARE GETTING LARGE AND STORING UP INFORMATION AND SLOWING DOWN THE SYSTEM AND PERFORMANCE.
GO INTO CONTROL PANEL LOOK FOR PERFORMANCE FOLDER
VIEW PERFORMANCE DETAILS IN EVENT LOG
OPEN FOLDER THE FOLDER SHOULD SAY
EVENT VIEWERS
GO TO FILE AND OPEN IT
OPEN OPTIONS
DISK CLEAN UP
DELETE FILES YES
OKAY
OPEN ACTION
CLEAR LOGS
YES CLEAR LOGS OR SAVE LOGS
YES OR OKAY
REBOOT SYSTEM
MAKE SURE YOU DEFRAG THE DRIVE AFTER CLEARING ALL LOG ENTERS BECAUSE ITS GOING TO CHANGE THE PERFORMANCE OF THE SYSTEM
ROD
Feb 24, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Jan 28, 2009 | HP Compaq ProLiant ML110 G4 Server
Acer Aspire 5735 Notebook Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
