Question about Pool & Spa
Pump runs for a minute or two and then stops for fie or ten
  • westend1 Jun 21, 2009
    this pump is now runnning again on its own. we still have a probelm though. it is attached to a 50 foot exension cord and when the pump comes on, the lights dim and the pump seems to run at 3/4 power. then it kicks in all the way and the lights go back to normal. i am wondering if the length or thickness of the extension cord is a factor and preventing enough powser to get to the unit when it starts
  • 3,230 Answers
You have a magnetek motor and it is overheating and cycling its thermal overload. A local electric motor repair shop may be able to fix it however it will likely need to be replaced. It is to costly to repair the motor if the damage is in the windings.
Assuming at that low a horsepower it is 115V, the likely replacement motor is a catalog #BN37. We sell it for $157. You are usually better off replacing the seal when you replace the motor and most Jacuzzi pumps are either a 200 or 1000. They should be around $5.
Good Luck!!
Thanks
Posted on Jun 20, 2009
  • Mukesh Kumar Jun 21, 2009
    Try a external power cord.
Put in a new fuel pump car still won't start has a security light on what do we do to get it started
If the Security Light is on but is not flashing, the security system is fine. If the security light is flashing then turn the ignition key to the run position (do not start). Wait over ten minutes and then try to start the engine. After the ten minutes you should notice that the light stopped flashing. If the engine starts then you do have a problem with the Passlock Security System.
Feb 28, 2014 | Mercury Grand Marquis Cars & Trucks
I have a 1987 Plymouth Voyager that starts, fuel pump comes on but it just runs a few seconds and stops. If you turn the key off and back on, the fuel pump comes back on but shuts back off in a few se
On the fuel rail will be a small round valve type thing with a rubber vacumn tube running to it ,check the tube and make sure its connected as this will stop it from running as it opens the fuel rail for the injectors
Jan 03, 2013 | Cars & Trucks
D3500 dually diesel has rough running problems for about ten minutes. Then runs great. Smoke is blue/white at first and truck wont run over 1800 rpm for ten minutes; then runs fine. I am told that it is...
I would look more at your injector pump than the lift pump....Dodge does have a problem with there fuel delivery ( not enough consistent PSI ) which in turn takes out the injector pump mainly because the pump has be running to lean...So look at replacing your delivery pump with something 14PSI or greater, unfortunately sounds as though you will have to get your injector pump either replaced or rebuilt
Dec 31, 2010 | 2002 Dodge Ram 3500 Truck
My dodge durango stop suddenly , the engine was off,tried to cranck it but not starting ,after ten to twenty minutes started .i drove for ten km.then off again. kindly advice
Sounds like your fuel pump is going out. Next time it doesn't start, cycle the key from off to run position (not start) and listen for the soft hum of fuel pump. If it's not there, you need a new pump.
Jul 22, 2010 | 2004 Dodge Durango
Hyd controls get hard after machine has run ten
You got a pressure crossover problem there , main pump pressure is leaking into the servo system I would suspect the pump.
Apr 10, 2009 | Garden
Pool & Spa Logo
126 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
