Question about Gateway 450SX4 P4-M Notebook
Central processing unit for Gateway computer
I want to upgrade the CPU in my 9-yr. old Gateway #450 desktop PC to something faster than the original one that's in there now. I've replaced the hard drive and the modem several times and I know how to take apart a PC and reassemble it. The motherboard on this PC is proprietary as I understand it, and there may be other compatibility issues with a new CPU.
The problem I have is just the fact that the original CPU is so slow by today's standards but may not be replaceable because of the age of the unit. Can you help?
  • Ragnar Nov 07, 2007
    I'd thought about doing precisely what you've suggested. The computer shows come to the Baltimore area on a more or less regular basis, so I could probably get one there, and sometimes the local places like Office Max have specials where they'll build your computer to your specs...I think I'll ask.
    Thanks muchly!!
  • Jim Haley
    Jim Haley Jul 22, 2012
    I have a Gateway 450 mini tower. It came with only 64 MB of Ram, so I was able to upgrade to 256 MB. I took out the 8.4 GB hard drive and replaced it with a 40 GB, then installed XP pro, using that, I increased the virtual memory . I hope that works for you.
    Problem Solver:
  • 11 Answers
For a couple of hundred dollars you can get a much faster bare-bones desktop or tower and mb cpu combination and move your hardware to it. Upgrading your 450 isn't worth the trouble though jumpers on the board should handle upgrades to maybe 600MHz.
Posted on Nov 03, 2007
How cpu's work properly
What is a CPU?
The Central Processing Unit, or CPU, is considered the brain of a computer.
Without this vital component, the computer wouldn't be able do any of the functions it is capable of doing. Basically, it is a chip that handles the moving and processing of data.
With each new upgrade, the CPU is getting faster and more powerful.
Speed and reliability is the name of the game when consumers are comparing CPU chips in the new PCs. F
or some, the brand of CPU is the major selling point for many when buying a new computer. The faster and more powerful the CPU, the more the computer will sell.
How Does it Work?
The CPU sits in the motherboard as the central unit.
All of the other hardware components and programs installed on the system must go through the CPU before their function can be carried out.
The CPU's job function is important and enormous in scale.
When a function, program or piece of data is called, the CPU pulls it from Random Access Memory (RAM) and any other hardware in order to process it.
The CPU then reads the instructions associated to the task before sending it back to RAM. The instructions that the CPU receives pertains to calculations and data transportation.
The system bus is the trail that the data must travel before it is executed.
It is the CPU's job to make sure that the data is guided through the system bus to be processed by the CPU and then on to the next step.
With every stop on the system bus, the CPU makes sure that the data gets there in the correct order.
hope this helps
Oct 11, 2012 | MSI K9N6SGM-V Motherboard
The comp. is very slow what is a cpu. when u turn it on it takes hours to load
The central processing unit (CPU) is the portion of a computer system that carries out the instruction of a computer program, to perform the basic arithmetical, logical, and input/output operations of the system. The CPU plays a role somewhat analogous to the brain in the computer.
The faster the CPU, the faster the computer.
You might want to look in to upgrading the CPU or RAM.
Sep 01, 2011 | Toshiba Satellite A135-S4467 Notebook
Am I able to to upgrade the original cpu that came with the pc? And or mother board? Intel Pentium D cpu 2.80ghz 32 bit os
Hi . you should check with intel web site as to what you can upgrade to , it has to be the right cpu other wise your system will not work , so check with intel and let me know if this helps you , if not i will research it myself....................Roy
Jul 20, 2011 | Gateway GT5040 PC Desktop
I can't connect to cpu from motherboard
That's a Northbridge chipset problem then. The Northbridge chip of the motherboard chipset handles the faster capabilities of the computer. The Processor, Ram memory, and High-speed graphics,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short,
http://en.wikipedia.org/wiki/CPU
Or are you referring to a personal desktop computer as a CPU?
In this case you need the Front Panel header pinout.
The plastic front of your computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) go to from the Front Panel, is the Front Panel header.
What motherboard is this? Manufacturer name and Model Number, or manufacturer name, and Model Number of the desktop computer.
State back in a Comment.
Regards,
joecoolvette
Jul 18, 2011 | Computers & Internet
I have a mobo C51PVGM-GB that I would like to upgrade the video card and not use the one built into the Mobo.
You are upgrading the graphics.
Instead of using Integrated Graphics, you will be using a dedicated graphics card.
Integrated Graphics is also referred to as OnBoard Graphics.
On the motherBoard.
The GPU (Graphics Processing Unit) is soldered to the motherboard.
It is not a video (Graphics) card.
A dedicated graphics adapter card has it's own GPU, and graphics ram memory.
http://en.wikipedia.org/wiki/GPU
Information on the Gateway 4006136R - Nvidia GeForce 6150 AM2 uBTX 1394 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006136R/4006136Rnv.shtml
Viewing this small photo of the motherboard, the Orange long slot you see is a PCI Express x16 slot.
1) The Northbridge chip is a C51PVG
2) The Southbridge chip is an MCP51
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100_and_6150_series
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply Processor for short)
3) Made by ECS
4) Has an AM2 processor socket on the motherboard, for AMD processors.
Continued in an additional Comment.
Jun 12, 2010 | Gateway GT5220 PC Desktop
When we try upgrading xp to windows 7 the upgrading failed because our cpu is old can i upgrade my xp to windows 7 using a old cpu or use a new cpu
NO you cannot, on that same computer, no matter what OS, because, you MUST change your central Processing Unit, CPU. To allow Windows 7 to work correctly.
Feb 07, 2010 | Microsoft Windows XP Professional
Wat are the problem if the cpu was not functioning? is there an problem about my cpu? or it might be change my cpu?
CPU If Central Processing Unit stops functioning your system is dead. If you think your CPU is too slow you can look into upgrading to a faster CPU, but it has to match with your chip-set and would have to be installed by someone that understands computer architecture. mysleuth
Mar 16, 2009 | Intel Pentium 4 517, 2.93 GHz...
Got a gateway essential 450 mhz tried to upgrade the cpu to 1000 mhz
just cuse p3 doesnt meen it will work maby wrong fsb also ok
Jan 28, 2008 | Gateway Essential 500 PC Desktop
Upgrading PC CPU
Put in as much RAM as you can afford. I've found that this is the quickest, easiest way to speed up a computer.
Nov 02, 2007 | Gateway 450SX4 Notebook
Computers & Internet Logo
81 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
