Question about Sanyo DS27510 27" TV
How to fix a sanyo tv if it gets stuck on video 1/ me and my freind was going to play the wii and we did.we came back later and was gonig to watch tv but the universal remote wrolud not work and we got a new one but it did not work either. so a hit the menu button on the tv and all i got was picture/sound and menu language.
4 Suggested Answers
SOURCE: Sanyo tv stuck on "video 2"
I had the same problem and had to buy a new remote. Just Google Sanyo remote--it's the more expensive one with more buttons. Good luck.
Posted on Dec 30, 2008
  • 11800 Answers
SOURCE: have a sanyo 20" flat screen. i own the original
This isn't a problem with the remote - it is working just fine since you can go in the "menu" - it's the tv, it is locked. Since you weren't the one that locked it then it was caused by a malfunction of the control processor.
The only thing you can do is to reset the tv to factory condition: unplug the tv for 5 minutes, start it up , wait 30 second and then press twice the RESET button on the remote.
If that doesn't fix it then the processor has been damaged,. The tv is fixable (all you need to do is to replace the control processor, and the part is cheap - $25) but the labor necessary for that (over 3 hours of tedious soldering) will cost you more than a similar new tv.
Posted on Oct 17, 2010
  • 8457 Answers
SOURCE: My 27" Sanyo DS27800 when
U using the RCA AV cable Y,R,W plug into those tv video input holes wright?Tries another RCA Y,R,W AV cable,see if it work?U have tools like a soldering iron,a roll of solders,also can u do basic soldering?Tries take some alchahol clean the Yellow input hole and take the tv aparts resolders it connections joints,now the video out it should work again,if not yellow input hole might be shorted require replacing.
Posted on Jan 27, 2011
My wii get frozen when trying to play games, or even watching Netflix. I unplug it, wait 2 minutes, and then it works sometimes, and sometimes it doesn't . It gets stuck and says loading, then I...
Could be a few things.1.) Have you ran a firmware update lately? If so, I'd suggest reverting to factory settings.2.) If you haven't updated, it sounds like it's internal. Could be faulty hardware (4 years is quite awhile). Contact nintendo.
May 08, 2012 | Nintendo Wii Console
Sanyo plasma hd tv 50 inch screen i am trying to hook up my granddaughters wii on our sanyo plasma hdtv cannot get it to show up in color on imput 2 or 3 video imputs. we have a dvd/vcr on video 1 imput...
Hi, take out the dvd player from port 1 and try the Wii in port 2 or 3 if the picture is good on the wii then you will need to get a 1 way scart lead for the DVD, not a fully populated one as these can cause interference between video inputs.
Hope this helps
Feb 11, 2011 | Sanyo Televison & Video
Connecting a wii system to a sanyo DP26648 tv
It has to do with the type of input - Video2 and 3 are Component video inputs, requiring a 3- wire component video cable (Red,blue,green for video, red/white below for audio). Video 1 is for analog equipment (Yellow for the video, red and white for the audio). Unless your Wii comes with a component video out cable and jacks (same red blue green), you'll have to use video 1 for the Wii, and use Video 2 for the dvd. You'll need a component video (3-wire) cable for your dvd, which should have the jacks for it. You can use the present cable you're using for the dvd, but you'll have to change the connections on the back of the dvd to component video out, and you'll still need another 2-wire cable to connect the audio out on the dvd to the audio in on Video 2 on the tv.
Here's the manual for your tv - look on page 8 for these connections. the Wii will be an analog connnection, the dvd will be a digital connection.
http://www.sanyotv.com/DP26_32648%20Owners%20Manual.pdf
Hope this helps!
Mar 13, 2009 | Sanyo DP26648-R 26 in. LCD TV
My ps3 is stuck on 1080p mode. i was playing on a freinds tv. my tv is only 1080i.whn its hooked up to my tv i get sound but no video plus i get nothing from the component cord short of taking back to my...
Put the ps3 into standby mode. Then press and hold the power button for five seconds. The machine will beep, and the video will be reset back to normal mode.
http://answers.yahoo.com/question/index?qid=20080621130655AAkJqSr
Dec 06, 2008 | Video Game Consoles & Games
Wii video is black and white
Possibly you've plugged the video into the component (RGB) portion of the input - this calls for 3 connectors (Red, Blue, & Green) and if you only plug one in from a composite it comes out grayscale. If you only have one video lead (yellow connector) make sure it is going to a composite connection which should also be yellow. Otherwise, more info is needed about your connections.
Nov 02, 2008 | Nintendo Wii Console
Input channels
I would try to replace the AV switch IC which directs i/o signals to the tv decoding stage.
Jun 25, 2008 | Sanyo DS24205 24" TV
Hook up the Wii
If you have the remote for the TV, it should have an input button on it that would change the video mode. If you have a universal remote, often the tv/vcr button will do that function on the newer model TVs.
Good Luck
May 22, 2008 | Sanyo DS31590 31" TV
Apr 13, 2008 | Sanyo HT32744 32" TV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Wii Sports
Maybe the Nintendo Wii overheated because you played with it for too much. Give it a rest and go back to it later.
Dec 16, 2007 | Nintendo Wii Console
Sanyo DS27510 27" TV Logo
456 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
