Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hi there! We have a Kenmore Elite HE 3t front
Hi there! We have a Kenmore Elite HE 3t front load about 3 yrs old. I turn it on by holding down the start button for 3 seconds then it clicks on but then flashes on the screen ''F 11'' & wont operate. I have had it go as far as fill with maybe 3 liters of water then shut off & flash ''11'' & beep beep at me every 20 seconds like it is stuck or something?? Is it a re set button that can knd of erase this mode or what ever happened to it? It happened once before & after 3 days & some prayers she worked!
Thank ewe for any advise.my email is: info@wool.us
No we are not rying to wash one of our ewes:)
model 110.42922 200
ser CSP 2810391
Ty 199 AKP702/WT
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite 3t is banging in the spin cycle and the plastic ring behind the rubber boot is shredding. Any suggestions?
are you using a gel soap if not that may be your problem powder soaps cannot be used in front load machines it damagege the bearings in the back of the tub
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
Water running out the botton
sounds like you have lost your sump
take off the back of the machine
watch the bottom of the tub and turn on the water
you will get a much beeter idea of where its comming from
Oct 06, 2009 | Kenmore Elite 45986 Front Load Washer
I have a code that is 888 on my kenmore elite HE 3t. Does someone know what this means. How do i take off the capartment to check the wires?
there are 3 screws in the back that will take off the whole top then you will see inside.is there any other codes?
Mar 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 3t washer
unplug machine, go down to the pump motor and squeeze the tab and connector and pull it away from the pump.
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Replacing the rubber gasket on Kenmore elite HE 3t
probably some rubberize installation are screw to the case or body/ you only need pollout are screw driver philips or flat .
Jan 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
166 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
