Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Put new switch oster 76 forgot how to wire it back
Middle wire goes to incoming power an the other two wires get connected to the terminale that sets against motor,was wondering where you bought the switch
Posted on Aug 18, 2009
How to fix the switch on my oster 76 classic clippers
Check out My Video on how to replace Oster 76 Switch at Mannys-Sharpening.com Service You can Trust Since 1990
Jan 06, 2011 | Oster 76076-010 Hair Trimmer
I just replaced a faulty switch to my Oster hair clippers Golden 5 single speed. I forgot how to reattach the switch and power cord wiring. Whoops?
I had the same problem with an Oster 76. I disassembled the unit and replaced the switch but my "repair" caused the house fuse to blow.
If you're a "once in a while user" such as myself, you may find my eventual solution useful: I screwed the terminal ends of the cord directly into the main body of the clipper. This made the on/off switch the power cord itself.
Aug 06, 2010 | Oster Golden A5 1-Speed Universal Motor...
I had to replace the back of my 76, cord, switch and all.. well i got the piece and when i install it my machine dont wanna power up, any suggestions ?
if your 76 clipper is a older model with a gray switch you install to black wire wrong. Now if this 76 is a newer model you have the tang position wrong. your best bet Contact mannyssharpening@yahoo.com they can help you with step by step instruction.
Feb 18, 2010 | Oster 76076-040 Hair Trimmer
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
Simple question: Are the Oster 76 2-speed, the Oster Crewmaster 2-speed, and the Oster A5 2-speed all the same clipper with different detachable blades?
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Oct 03, 2009 | Oster Golden A5 2-Speed Universal Motor...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Lubricating motor
Here is schematic for repair and service. This is the A5, it is the animal version of the Classic 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
and if u need parts see the link below for schematic and parts list for the 76.
http://www.clipperrepair.com/parts.htm?mid=106
Feb 01, 2009 | Oster 76076-010 Hair Trimmer
Temp too high
lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Oct 05, 2008 | Oster 12-Bottle Wine Cellar - Black
I need help!!!
if you have a single speed (on off) clipper, it should only have 2 wires which go on either way. If you have a 2 speed (off low high) clipper there should be 3 wires, and they must go on exactly as they were. you won't blow anything up if you wire it wrong you just wont have 2 speeds . . just keep turning them around till you get it right.
Feb 17, 2008 | Oster 76076-010 Hair Trimmer
Oster 76
change the carbons
May 25, 2007 | Oster 76076-010 Hair Trimmer
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
210 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Chuck
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
