Question about HP Photosmart R817 Digital Camera
The built in flash stopped working in my HP R817. I got new batteries, still doesn't work. HELP!
    Sergeant:
  • 321 Answers
Repalce flash bulb
Posted on Jun 20, 2009
Sir i have problem in hp g61 i;m getting that message upon installing new bios. my touch pad is going crazy, so i was advised by hp to update the bios from F 0.6 to F06 f. however when i turn the computer...
never flash BIOS or risk this., only flash if
1: THERE IS A PROBLEM WITH PC.
2: HP TOLD YOU the bios fixes this exact problem.
3; getting the correct bios for this pC can be difficult.
4: flashing with a dead battery can fail,
5: If the flash fails, try again. repeat the flash,
6: if the BIOS is now dead, take out coin cell for 15min.
put it back see if BIOS key works now. and reflash it using only the correct new BIOS FLASH binary files only from HP and matching
your exact unstated, service TAG data. (i bet you did not even look or get it right here, as many do , and then brick the PC)
the touch page worked when new.
so how can BIOS suddenly go bad?. (it cant)
no windows OS stated
if you are still running the correct OS on this G61.
to make the pad work takes:
1: pad not damaged or cables inside not loose.
2: correct OS, that HP supports, (windows 10 may not be)
3: only HP version and disks loaded for OS and all drivers, not microsofts.
4: remove and load the correct mouse pad from HP.
5: bingo it works and no flash needed, nor desired ever or 99.9% of all cases. leave BIOS alone and win. is my motto.
what G61, since you never said, my guess you dont know
and if true, then how'd you get the correct bios.
you didnt. (my guess and is right most times when bios mangles)
here ill click 100 for your, my wild guess.
it runs vista and w7 only, are you >? hp disks not MS?
year 2009 made.(as old as....)
see results in last photo. (guessing your unstated service tag)
btw, next time ask for mouse pad help
and leave BIOS ALONE.
Apr 30, 2017 | HP Compaq Presario C502US Notebook
New computer with windows 7 will not allow run install disk for R817 digital camera
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use Windows Photo Gallery or any other photo cataloging program.
Sep 05, 2011 | HP Photosmart R817 Digital Camera
Chamberlain remote has stopped working, new
WHEN YOU CHANGE THE BATTERY NO NEED TO REPROGRAM THE REMOTE.
THE FLASHING LIGHT TELLS YOU IT IS SENDING A SIGNAL THAT IS BEING RECIEVED IT IS JUST NOT THE CORRECT CODE TO OPEN THE DOOR.
REPROGRAMING THE REMOTE SHOULD SOLVE THE PROBLEM
HOPE THIS HELPS
Sep 28, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Camera self- diagnostic doesn't work
I had this exact problem when I had not used my camera for some time. For me the solution was to take out the flash card, and turn on the camera while pressing the flash button. This allowed me to run the self diagnostic test (which were ok by the way), and then after turning the camera off and on again it worked!
Dec 23, 2008 | HP Photosmart R817 Digital Camera
Zoom is broken
just call bob the builder; because 'yes they can"
Oct 28, 2008 | HP Photosmart R817 Digital Camera
HP Photosmart R817
Something is wrong with the battery or the charging system. I just charged it over night and it works now. The battery still dosn't last very long .
Oct 07, 2008 | HP Photosmart R817 Digital Camera
HP Photosmart R817 5.1 Megapixel
Lens does not come ut when we turn camera on?
Jun 30, 2008 | HP Photosmart R817 Digital Camera
Screen not working
It could be that the connection to the screen has loosened up for some reason. If the warranty is void you can try to open it up (if you're up to it), taking the bottoms screws out, and then only the one's close to the screen side on the sides (hehe I hope you understand what I'm trying to tell you ;) )
The screen should be the first thing you see, if you loosen the 4 screws that hold that you can see the connection, just try to fasten it a little bit better, and then screw everything back to it's place.
Let me know if that didn't do the job :)
*I can not be held responisble if you decide to take something apart, It's your hands*
Feb 15, 2008 | HP Photosmart R817 Digital Camera
"Charging Flash"
i just posted the same problem a few minutes ago and now i have the solution!! got to this link http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=437509&lang=en
download the driver if needed (the firmware installation will tell you if you need it) and then download the firmware. immediately after i downloaded the firmware, the "charging flash" went away! hope it works for you too~
Aug 22, 2007 | HP Photosmart R817 Digital Camera
Camera locked up
Lens motor shot? Checkout the customer support at HP However if it is out of warranty I guess you will find the price of a repair is well on the way to the next camera
Aug 01, 2007 | HP Photosmart R817 Digital Camera
HP Photosmart R817 Digital Camera Logo
209 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
