Question about Kenmore Refrigerators
The information you provided was totally incorrect, all that was required was clean the condenser fins. saved $200.00
I cleaned the lint from the condenser fins, the refrigerator works same as new now.
Posted on Jun 21, 2009
Need help wih dehumidifier Kenmore model#2519970180000451
well first ive never read in any manual that tells the homeowner to remove cover on any apliance , in fact the only cleaning ive ever read is clean the filter , this is right in front on side and slides right out and can be washed in sink with soap and water (do not scrub) but yes cleaning the condenser coils will require you to remove cover this is purposly made somewhat a challenge to discourage homeowners from hurting them selfs as there are live electrical parts and sharp edges inside , i sugest a qualified appliance repairman be contracted to have a look
Oct 16, 2014 | Dehumidifiers
Tip
Cleaning Air Conditioner Condenser Coil with Pictures
The most important Air Conditioning maintenance that needs to be done every year is the cleaning of the condenser coil. Doing the job of cleaning the A/C coil is the best way to make sure that your air conditioning system is working efficiently and giving you the best performance possible.
The tools needed to do the air conditioner condenser coil cleaning will be:
Garden hose with nozzle
Garden pump sprayer
Condenser coil cleaner (can be purchased at HVAC Supply houses, or many hardware type stores)
Hand tools needed to remove condenser fan
To do the job correctly you will need to first turn off the power to the unit and remove the condenser fan.
Once the condenser fan is removed then, you should wet down the condenser fins with a garden hose. Use nozzle that will give you a high volume spray but not with high pressure. Too much pressure will bend the fragile fins and cause them to shut off the ability of the air to flow through them, this is want you want to avoid. You want it to be as easy as possible for the air to get through the fins, for the best possible heat exchange.
After wetting the fins, you then will need to spray the fins inside and out with a foaming coil cleaner. Make sure to wear eye protection and hand protection. If you have sensitive skin, you may also want to wear long sleeves to protect exposed skin. I buy it in a concentrated formula then dilute it with water to the proper working formula. You may need to go over the fins a couple of times with the coil cleaner to get it worked into the fins. Allow the coil cleaner time to work the dirt loose and boil it out of the fins.
After about fifteen minutes start to rinse the coils with fresh water. This will take a long time and lots of water to fully rinse the coil cleaner from the fins. It also is very important that you get everything rinsed fully. Failure to do this will result in excessive dirt accumulation and also can cause corrosion. Make sure that the water is running clear and that all bubbles are gone before stopping your rinse.
Then reassemble the condenser fan, turn on the power, and check the operation of the unit. It is okay to run the unit immediately after washing it. The water will not hurt the unit.
You now will have an Air Conditioning unit that will give you the best possible performance!
on May 15, 2011 | Heating & Cooling
Frgidaire dehumidifyer runs but coils do not get cold
the condenser is probably clogged with dust thus restricting the air flow required to cool it down. if it has a filter on the front, take it out and clean it. if it does not, try to remove the front cover and, using a stiff bristled brush and simple green, clean the fins on the condenser then hose it down. if there, then, is no air flow, check the fan. replace if necessary.
May 10, 2012 | Frigidaire Dehumidifiers
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
How to unblock pin2 code in samsung champ c3303
Puk/PIN code is a secutity code that protects your SIM card, it is unique eight digit code specific to your SIM card. This code is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -
The PUK code is in your SIM card documentation Starter Pack.PUK stands for Personal Unblocking Key.
You can contact to your mobile phone provider, along with documentation or you total identification, and soon after they could give the PUK code.
If you need more information, reply me soon.
Thanks
Hope this helps.
Feb 20, 2011 | Computers & Internet
My side by side roper wont cool
The condenser fins may need to be clean. Provided that everything else is okay, consider cleaning the condenser with a long flat brush and blow the fins with compressed air to dislodge all traces of lint.Then, you should big improvement.
Jan 06, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
The freezer is about 65% cold - the ice cream is melted but the ice cube trays have not. The fridge is about 50% cold, no food has spoiled yet. What is causing the problem?
Clean the condenser fins. Lint build up in the condenser fins is inhibiting heat transfer. Just clean the condenser very well and that might solve your cooling problem.
Jan 06, 2011 | Avanti FF1102SS Top Freezer Refrigerator
What is involved in cleaning the compressors on commmercial reach-in coolers?
the compressor itself can be cleaned with any mild cleaner/degreaser and a rag (the fins are aluminum and the tubing is copper, so no heavy-duty cleaners). if you mean the condenser (coils), compressed air works best. if the pressure is too high or the hose nozzle too close, the fins will bend, so be careful. if the dust/dirt/obstructions are really coated on the fins, there are cleaners that you can spray on. as long as you know can clean what's behind it and can soak up the puddles, you can spray simple green, let it set for a little, then use the air hose to blow it out. you can use a fin comb to straighten out the bent fins. for the evaporator fins, just use air.
Jul 20, 2009 | Kolpak WARRANTY-3/4HP 5 Year Walk-In...
High head pressure, normal suction pressure? what r some things i can check for?
Dirty condenser or slow or not running condenser fan. What are the pressures?
Jun 28, 2009 | Goodman Heating & Cooling
Pressure keeps dropping on my jaguar boiler, no leaks in house but hot water coming from overflow outside
hi In most air-conditioning systems, the condenser unit is located outside the house and is prone to accumulate dirt and debris from trees, lawn mowing, and airborne dust. The condenser has a fan that moves air across the condenser coil. You must clean the coil on the intake side, so, before you turn off the power to the air conditioner, check to see which direction the air moves across the coils. Here's how to clean the condenser:
Step 1: Cut down any grass, weeds, or vines that have grown around condenser unit; they could be obstructing airflow.
Step 2: Clean condenser with commercial coil cleaner, available at refrigerator supply stores. Instructions for use are included. Flush coil clean (do not use hose); let dry.
Step 3: Clean fins with soft brush to remove accumulated dirt. You may have to remove protective grille to reach them. Do not clean fins with garden hose, as water could turn dirt into mud and compact it between fins. Clean fins very carefully: They're made of light-gauge aluminum and are easily damaged. If fins are bent, straighten them with fin comb, sold at most appliance parts stores. A fin comb is designed to slide into spaces between fins. Use it carefully to avoid damaging fins.Step 4: Check concrete pad on which condenser rests to make sure it's level. Set carpenters' level front to back and side to side on top of unit. If pad has settled, lift pad with pry bar or piece of 2-by-4, then force gravel or rocks under concrete to level it.
Sep 12, 2008 | Heating & Cooling
Refrigerators Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
