Question about Mitsubishi VS-50607 50" Rear Projection Television
My Sony ANalog T.v. shuts off by itself. Im wondering what causes the problem?I now a bit about electronics, but I really dont know which section has the problem. thanks for the aid. kirk
So my door won't latch the latch itself wont lock the door in place and the alarm goes off everytime i start the car or shut the door so i took out the fuse for the alarm so i could drive it so im...
No point wondering - only examining the door internals will reveal why the latch doesn't work. Mostly it is the result of poor maintenance, the result of a maladjusted striker/hinges or a very dusty environment, though sometimes a spring will break...
Sep 14, 2017 | 2004 Chevrolet Aveo
Hello, I have a prob with my Sony HCD-RV999D I just bought it from a friend, I plug the outlet everything is normal, I press the power button, the system turns on normally, but after 3 second it turns...
The reason this happens is because it takes about 3 to 5 sec. for the output circuit relay to kick in after power up, im sure at this point is when your receiver shuts off and flashes red. You have a bad output Transister its shorted to ground and the sony's protection circuit kicks in and shuts it down. Unless you are a electronic Tech. you will have to take it in to be repaired its going to be about 120 dollars to repair. Now im assuming your speakers are ok, if you have them hooked up when you do this try disconnecting them and try to power up if it does you have a shorted speaker, but normally Sony just displays overload protection on the display. Im sure you have a shorted Trans. sorry for the bad news good luck.
May 18, 2010 | Sony Audio Players & Recorders
Why does my converter box turn itself on and shut itself off?
set your power down to off most boxes are set to turn off in 4 hours
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
My new installed psp analog stick doesn't work
most of the time when you think that your joystick is messing up its really just the psp's motherboard that is messing up.
choices=get a new motherboard or get a new psp
Feb 05, 2009 | Sony PlayStation Portable (PSP) Console
Sony 52 inch projection Screen keeps shutting off.
not if it keeps repeating the same cycle over and over..it cost 300 once and if you have it fixed again thats another 300 and if it happens again so on and so on....
Feb 04, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
On off light never shuts off
Clarification: When you "switch off" the unit, does the light stay on, but the steamer itself shut off (cools off to no steam)? If this is the case, only the LED does not light (which will not affect actual performance, other than being a "false" indicator driving some users crazy) like an Engine light that stays on in your car. It is likely a bad connection rather than a bad LED (Light Emitting Diode indicator). If the steamer portion is powered on all the time regardless of the switch position, try turning the temperature settings all the way down on the base and iron before unplugging unit to prevent the arcing (sparks) from damaging the input AC plug.
Solution: you will need a small Security Torx Bit/Driver to take unit far enough apart to inspect, troubleshoot and determine cause. You will also need an analog or digital multi-meter to check the unplugged unit' switch using self-powered ohm-out (continuity check) function, testing forward & reverse diode for lo & hi resistance reading respectively, (if you use the Rx1 range, the diode will glow slightly in one direction if it is good & you use an old analog meter). If you are so inclined or know somebody into electronics to do this, you can get these tools at Harbor Freight for $10-$20, good luck and keep in touch.
Apr 26, 2008 | Rowenta DG5030 Iron
Lens wont shut completely
hello, as you said lens cover does not shut it means camera is in working mode so naturally it drains the batteries. Actually the problem is in the lens assy. so go to samsung shop. good luck...
Jul 27, 2006 | Samsung Digimax S500 Digital Camera
Open Questions:
See all Mitsubishi VS-50607 50" Rear Projection Television Questions
Mitsubishi VS-50607 50" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
