Question about York Furnace Draft Inducer Blower Fasco # A224
York diamond 80 hvac blower and comp wont start on automatic
Heater worked all winter replaced thermostat has 9 month old emercon 4702g curcuit board flashes slow green
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Posted on Oct 11, 2009
York Diamond 80 control board blew out on the blower connection
I would first check the blower to be sure it is ok. If so then the control board would need to be replaced.
Dec 11, 2013 | York Tools & Hardware - Others
York diamond 80 fan starts running blowing cold air before furnace ignites..replaced thermostat
OK so you replaced the Thermostat huh? OK well then did you also replace the Thermistor Temperature Sensor? or whatever is used? As often it's BOTH, also check the wiring from the sensor to the host, in any event if it's NOT that then all it can be is the controller board, most likely the Micro? Check any and all sensors first though.. try to get a service manual too, it's hard without one?
Oct 20, 2011 | York Furnace Draft Inducer Blower Fasco #...
York diamond 80 heater does not fire up
Mostly likely the problem is in the pressure switch that tells the board that the blower started and it is okay to fire the burner. The pressure switch is usually a 2" or so round thing about 1" thick, it will have one or two tubes coming out of it that go to the blower or heat exchanger. Make sure that the tube is not cracked or that it has not come off at either end.
The pressure switch can be jumped out to check out if that is the problem, but you need to jump it out after the cycle has started and the switch needs to open after a cycle for the heater to refire again, so that fix would be very temporary. But it may tell you for sure what the problem is.
Nov 14, 2009 | Heating & Cooling
York Diamond 80 Issue. AC and Blower work fine. Heat will not come on. Circut breakers are fine, all power is on. Any advise.
Open the furnace door. Turn the thermostat on, and hold the power switch on. Look for the service code on the control board. That should tell you whats wrong with it. www.FastACservice.com
Oct 12, 2009 | Heating & Cooling
Heater dont work
At the thermostat, jump R to W and if it heats, then you have a loose connection at the t-stat or a faulty t-stat. If it don't, you may have a blown blade style fuse(car style fuse 3 or 5 amp), damaged transformer(both due to a low voltage short), damaged control board, loose connection at the control wiring, blower door switch not closing or damaged, induced draft motor issue(try giving it a spin). Please work safe and I hope thus helps!
Oct 12, 2017 | Heating & Cooling
York  Furnace Draft Inducer Blower Fasco # A224 Logo
1,459 people viewed this question
Top York Tools & Hardware - Others Experts
vince
Paul Carew
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
