Question about Panasonic NV-HS1000 S-VHS VCR
Heads worn out on nv-fs100b
I need to get hold of a head drum assembly for tis model but not having any luck. Can you help? regards Dave
  • hotshotsash Jun 22, 2009
    No but I will. Thank you
  • Panasonic Master
  • 5,515 Answers
Have you tried Grandata?
Posted on Jun 20, 2009
Playpak
I guess the picture head may have become dirty.Please clean your picture head by inserting a head cleaning cassette.Hope this would help.
Regards
Jun 29, 2014 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Model NV-HD636 lines through replay picture. I have cleaned the heads several times. The tracking control appears to have stopped working. Is there any thing I can do?
If you have cleaned the heads using Servisol Video 40 and also any surface the tape touches and it still wont correct, your video heads could be worn out and the head unit needs replacing.
Have a look on the Curry's Partmaster Website to see if the head is expensive to replace, if it is I would say the machine should be replaced. Sorry if that is the case, but heads are the most expensive parts to go on a VCR.
Jun 21, 2011 | Panasonic Televison & Video
When you record something with the vcr it doesn't play back in color anymore just black and white. Thanks Henry
hello henry!
looks like the drum head needs to be cleaned. use a cleaning tape and try after that if color is ok. if not then propably you need to replace the head with a new one. this is a typical symptom when head gets worn out...
regards
Feb 20, 2011 | Toshiba SD-V392 DVD Player/VCR
I wish to replace the trimmer head on my Ryobi PLT3043A Whipper Snipper. Its just worn from to much love ???? I know how to replace the cord but wish to replace the cord haed assembly. I brought the...
Hold the shaft to prevent it from turning, then turn the trimmer head clockwise (viewed from the bottom) The cutter adapter has left hand threads. Hope this helps you out, as this is from the service manual. Best regards and good luck.
Dec 30, 2010 | Ryobi Garden
Panasonic VCR model number NV-HD640B comes up with fault code H01 - what is this and how do I fix it?
You have a Panasonic K Deck Mechanism, you can search for more free info on it via Google. Meanwhile H01 means no drum motor or drive, it's to do with the main VCR head not going around.
Dec 04, 2010 | Panasonic NV-HD680 VCR
Sound but no picture
Most likely the VCR needs a head cleaning. This is common when playing older or rented tapes as the oxide recording surface can flake off and clog the video heads. You can try a head cleaning cassette. Make sure to get a wet-type cassette which you moisten with the included cleaning fluid.
Unfortunately this is not always successful for severely clogged heads. It may be necessary to remove the cover and clean the heads with a chamois cleaning swab moistened with head cleaner. Hold the swab flat against the round drum that holds the heads and move the drum back and forth while holding the swab steady. Repeat this for each of the heads. The heads are fragile and can be damaged by incorrect cleaning, so you might want to see what a shop in your area charges. (The shop I worked in used to charge $20, but that was several years ago.)
There's also the chance there's been head failure or some other problem has developed, but dirty heads are very common.
Jan 08, 2009 | Panasonic Televison & Video
I have Panasonic NV-JF620 VCR and in Australia. The play back is jittery. Few months ago it was working OK. No damage. The picture is coming as small sections and jittery. Audio is ok. Tried it in 2...
Possibly either a tracking problem or the video heads are dirty. Please try a head cleaner which looks like a VHS tape but is meant for removing any dirt on the video head. Most models come with a liquid solution. Tracking normally is automatic nowadays, however, there are some variations and manual tracking (or bt the remote) should correct any jittery images.
If neither of the above is corrective, then your unit would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 20, 2008 | Televison & Video
Vcr help
This problem is certainly dirty or worn video heads, most likely just dirty. You could try cleaning with a tape head cleaner (wet type) If this doesn't work, contact me again, and I'll email you detailed instructions for cleaning.
Kind Regards....Dave
Jun 10, 2008 | Emerson EWV401 S-VHS VCR
WORN OUT VIDEO HEAD
Since model has discontinued it is difficult to get the head.
Mar 21, 2008 | Televison & Video
Hints for service
comon fault in it , as the picture stucks it is a weak heads you can get better result by cleaning the guides and if not so change drum heads regards , plz don't forget to rate thx
May 02, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Panasonic NV-HS1000 S-VHS VCR Logo
146 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
