Question about GE Washing Machines
Agitator will not spin.
Agitator on GE washer will not spin. Motor turns but clutch gets very hot.
    Sergeant:
  • 187 Answers
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.....
Posted on Jun 21, 2009
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
Agitator not spinning/moving during wash cycle (although it does spin during the spin cycle)
hELLO THERE:
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. an to repair it. Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Nov 17, 2010 | GE WHSE5240D Top Load Washer
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
GE Prodigy Washer: Doesnt agitate or spin. Fills ...
Hello, If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Thanks
May 19, 2010 | Washing Machines
Washing machine wont agitate
yes its belt.he is very correct.but many other possibilities check that also ----------- It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Sep 02, 2009 | GE Profile Performance WPSF4170WAA
Washer wont agitate.
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
May 05, 2009 | Washing Machines
Machine wont agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Apr 19, 2009 | GE WDSR2080D Top Load Washer
GE Washer Model WJSR2080V3WW Agitates, Pumps, but will not Spin
I solved the mystery of the non spinning washing machine by GE. I pulled the agitator off and to my horror was a broken " hub". This the part in the middle of the basket under the agitator. The transmission shaft comes up through the center of it. Any way, it was severely broken and wedged in so it would not spin. Not sure if this is the only problem but I am going to buy a new machine. I can not get it unbolted to replace the hub and don't want to **** around with it. THANKS.
Jan 25, 2009 | GE Washing Machines
Washing Machines Logo
112 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
