Question about NetGear WGR614 Wireless Router
Wireless Router to Computer connection problem
Hi I have just purchased a HP Pavilion dv4-1225dx laptop but I cannot get the wireless portion to connect to the wireless router. My router is a NETGEAR Wireless G #WGR614v.9. I have tried everything thus far with no success. Can you offer any suggestion please?
  • Carl Navarro
    Carl Navarro May 11, 2010
    You must not have tried "EVERYTHING" or it would work :-) Please be more specific. Is the router new? Does the laptop work through the router when you connect via wired? Is the blue wireless light on? Is the Wireless network card enabled?
  • 484 Answers
Look underneath the bottom of the laptop. HP is known for putting the wireless toggle switch under the laptop, to keep it out of the way. But that also keeps people from finding the switch to wireless, from wired.
I'd bet your laptop works if plugged into the network with an RJ45 cable.
Posted on Jun 20, 2009
  • 1,272 Answers
Follow the steps below on a computer connected to the router wired:
1. Open the browser(Internet Explorer or Mozilla Firefox) on a computer connected to the router.
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a password in the passphrase box. Apply the settings.
Make sure the wireless switch on the laptop is turned on and then perform the steps below to connect to the wirless network:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
Hope this helps.
Posted on Jun 22, 2009
How to connect hp pavilion to brother mfc9560cdw without router
This model Bother printer has a 10baseT LAN connection and can be connected to your LAN network and to your HP laptop via the wireless router. Connect a LAN cable from the printer to the wireless router.
To print from your HP laptop, check the IP address range your wireless router issues to your wireless network, it maybe 192.168.1.*** then configure the brother printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the Brother printer driver normally.
Then configure the Brother printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Brother
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Jul 07, 2012 | Brother MFC9560CDW AllInOne Laser Printer
How to connect wireless laptop
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Apr 25, 2012 | HP Pavilion 1137NR Notebook
HP Pavilion Dv6910us Entertainment Notebook Pc will not connect to internet
Mar 24, 2012 | HP Pavilion Dv6910us Notebook
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
I own a HP DV9000 my wireless quit working
Check the Device Manager to see if the Wireless LAN device is working and enabled. If not reinstall the Wireless LAN driver.
If the Wireless LAN is OK and enabled then sometimes when you bootup the Wireless LAN card doesn't get an IP address from the wireless router. This usually has a red X on the wireless connection icon and sometime you get an error message "Limited or no connection".
To get the router to issue the wireless LAN card with a new IP address, righr click on the Wireless icon and click on Repair.
You can also power down the router wait 15secs and power up the router again then reboot the computer.
If it still doesn't work you could have a faulty wireless card, see it your friendly computer shop can test it for you.
Jun 30, 2009 | HP Pavilion dv9000z Notebook
Ok, my previous question was answered about hp pavilion zx5000
You need to check whether it has compatibility with that router or not?
if yes, you need to make sure the operating system would meet all requirements...
Note - I am assuming that you have an inbuilt modem for wireless connectivity.
Check with vendor or router company if have any issues before you purchase.
Thanks for using "Fixya".
Jun 03, 2009 | HP Pavilion zx5000 Notebook
Wireless printing
hi vlewis, if you are trying to print directly from your Pavillion to your Officejet wirelessly, you should set an AdHoc type of connection. but if you have a wireless router that you are connecting to, you should have an Infrastructure type of wireless connection. here are some key points you may need to look at.
AdHoc (PC to Computer wireless printing)
1.make sure that the wireless adapter on both devices are turned on.
2.the wireless network name or the SSID should be the same with both devices.
3.you will have to set the same wireless security (like WEP or WPA depending on the capability of the devices)
4.install the printer drivers and utility and make sure that your printer utility shows connection to the computer
-voodoomox
i will follow this one up for infrastructure.
Aug 05, 2008 | HP Office Equipment & Supplies
How to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
New Vista laptop and problems setting up wireless
Chances are the wireless portion of the trendnet software is not compatible with vista. I would uninstall the trendnet software or let windows control the wireless portion of it.
Check to see if you are using any encryption ie. wep or wpa or wpa-tsk. If you are then you will need to enter the network key in windows.
good luck
smeags.
Jan 08, 2008 | Trendware TEW-432BRP Wireless Router...
Cant get online or pick up a wireless network?
A couple of issues and questions
First generally a wireless router in installed onto a network either to the ISP's modem or to another router that is connected to an ISP's modem it is not connected on the wan side to a computer (unless that computer is acting as a firewall or proxy server to the internet). Computers are generally connected with a wire to the (optional) switch portion of a wireless router or wireless connection.
Have you tried testing with a computer wired to the router to assure internet access is possible without worrying about wireless issues?
If you are considering encrypting the wireless router did you test it unencrypted first to assure the unencrypted radio transmissions work?
Is the wireless communication encrypted for other computers you own and possibly not for the HP you are now trying to connect?
Are you sure the distance between the wireless router and the garage is not an issue. Perhaps you could test and configure the connection in the room with the router and when it is working move it to the garage.
According to the product specs for the HP Pavilion it has built in wireless B & G you did not include the router manufacturer and model does it operate on the either wireless B or G?
Dec 08, 2007 | Computers & Internet
NetGear WGR614 Wireless Router Logo
136 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
