Question about LG WM2487H Front Load Washer
INTERIOR LIGHT STAYS ON AND NEW LOAD OF WASH WILL NOT START
Hello
We own a LG WM2487H*M and after a year or so our light will not go out after a wash....should stay on 4 minutes. The next load of wash can not be started until the wall power plug is pulled and plugged back in. Everything else works great....any ideas on what went out and the best way to fix the problem?
Thanks,Bruce
    Genius:
  • 1,847 Answers
Confirm that the door shuts properly the Door Switch button.
- Check for 120 vac between the power cord neutral (white wire no. 13) and the Push to Start Switch (gray wire no. 26) only the Door Switch button is pressed in.
- Check the wiring at the Door Switch and Push to Start Switch.
- Replace the Door Switch.
- Check for 120 vac between the power cord neutral (white wire no. 13) and the Machine Control (black wire no. 27) on the relay COM terminal only when the Door Switch button is pressed in and the push to start button is pressed in. Check also for 120 vac between the power cord neutral (white wire no. 13) and the Machine Control (red wire no. 28 on connector P1) only when the Door Switch button is pressed in and the Push to Start button is pressed in.
Replace the Machine Control if 120 vac is present in both places.
Replace the Push Switch if 120 vac is not present in either place.
you may also want to check the start button to make sure it's working properly
LG Contact Information
Main support number 1-800-243-0000
Posted on Jun 20, 2009
Soap ispencer jammed
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | LG WM2487H Front Load Washer
Water wont load why I put the machine on wash sometime it let water in at the start but then wont continue adding water to finnish the wash
Hello & Welcome to FixYa
The problem seems to be with the water inlet valve that has gone bad and needs replacement. Before replacing the valve try swapping the connections and clean the inlet valve. If the valve is fine then the problem is with the pressure switch that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 14, 2011 | LG WM2487H Front Load Washer
Thermistor on wm2487h*m lg washer
usually on the front outer drum wall. front of machine will need to be removed.
Jul 02, 2010 | LG WM2487H Front Load Washer
My LG WM2487H has water in the detergent cup at the end of the wash. It has happened twice now.
This is normal.
All LG washers use a siphon system to dispense soap, bleach and fabric softner.
Some times water will remain in the cups depending on the cycle used.
Jan 20, 2010 | LG WM2487H Front Load Washer
Adding to existing load
most machines wont let you due to safety reasons,the other way is to start again on the wash
Nov 02, 2009 | LG WM2487H Front Load Washer
LG steamwasher WM2487HRMA doesn't turn on
Greetings,
There is a problem with the computer. The computer will need replacement. I have seen this many times.Sorry.
Mike
Oct 27, 2017 | LG WM2487H Front Load Washer
Lg washer won't spin
Does it power on?
Does water come in at the beginning cycle? Do the lights come on?
Your motor has a warranty of 7 years from purchase date. Call 1-800-243-0000 for service.
Jun 16, 2009 | LG WM2487H Front Load Washer
LG steam washer leaks a small amount of water from underneath the washer between loads.
Hello.
Welcome to Fixya.
  • Inspect the water supply connections.
  • Inspect the drain hose.
  • Inspect the Water Pump.
  • Inspect outer tub for cracks or corrosion.
  • Inspect the tub seal.
  • Inspect the tub bearing.
Good Luck.
May 05, 2009 | LG WM2487H Front Load Washer
LG WM2487H*M Drum light stays lit after each load is completed
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
Feb 12, 2009 | LG WM2487HA Washer
LG WM2487H Front Load Washer Logo
108 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
