Question about HP PhotoSmart 7760 InkJet Printer
HP 845c - SOme colors will not print
I just changed the color cartridge and it did not solve issue. I am not getting yellow and the associated colors with a yellow mix. Could it be a print setting in color management? I do not understand cm.
    Scholar:
  • 59 Answers
HP is Famous for either the (drivers), dropping off, (and), or they need to be "reloaded" every couple of Months.
1st. try reloading the disk, or downloading the updated driver from the HP website.
2. try printing a "test sheet to see" if the yellow is working at all, just because "something is new, doesn't mean it's going to work.
3. open (depending on what windows) your running ,the tools, and go to advanced, and scroll down to where it says "DO NOT PRINT BACKGROUND COLORS", AND SEE IF THIS IS CHECKEDOR NOT, IF IT IS, UNCHECK IT, AND SEE IF THIS CORRECTS YOUR PROBLEM, GOD BLESS
Posted on Jul 03, 2009
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
I just installed a brand new HP 17 color cartridge in my HP deskjet 845c (as it appeared that the old one had run out of pink and yellow color) and now the new one will only print out in blue. I took out...
One of the first things I would do is called "footprinting" the cartridge. Remove the cartridge from you machine and firmly press the bottom of the cartridge, the print head, onto a paper towel. Use your other hand to apply even pressure from underneath the paper towel. This, hopefully, will cause ink to bleed out of the cartridge and onto the paper towel. Be aware that you may get ink on you and take measures to prevent it if necessary. A good footprint from that cartridge should yield three small rectangles of the three colors in the cartridge, it is ok if they bleed into each other. If cyan is the only color flowing you can try moistening the paper towel with some warm distilled water and gently holding this against the print head for a short while (30 sec), again ink should come out. If there the cyan is still the only color to flow there is nothing more you can do at home. Return the cartridge if you can.
If however all three colors footprint well then it may be a driver and/or firmware issue with the printer. I would try reinstalling the driver first, then upgrading the firmware is an upgrade is available. Those machine are getting older and probably do not have as much support available as newer machines do.
Mar 24, 2010 | HP DeskJet 845c Printer
Just changed the color cartridge and the ink light won't stop flashing and nothing will print?
check cartridge, remove and clear connector with alcohol and soft cloth, Put and check, if you do not help and you have a new cartridge, check on the new.
Sep 09, 2009 | HP DeskJet 845c Printer
HP Deskjet Color 845C Printer - Black Cartridge Problem
hi,
try to clean the nozzle with clean cotton w/ alcohol i think your cartridge has getting clog..or maybe it's getting empty!
rey
Nov 02, 2008 | HP DeskJet 845c Printer
Yellow Hue when color copying
I understand your situation, however let me explain you that whenever you try to make a copy or print, yellow cartridge takes part and provides its color in all the aspects. Please do check that you use the HP ink cartridges and try to clean the cartridges for every 15 days as this may reduce the issues of colors.
Feb 07, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP DeskJet 970Cse won't print yellow
Here is a link to hp's web site. They will troubleshoot your issue. This link is linked to a page talking about HP Inkjet Cartridges and Media - Missing Color, Wrong Color, or Streaks in the Printout. There are several links in this site to go off of and troubleshoot further. Hope this is helpful:) http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&lc=en&cc=us&dlc=en&product=60097&rule=34749&lang=en Jason
Sep 04, 2007 | HP DeskJet 970cse InkJet Printer
HP PhotoSmart 7760 InkJet Printer Logo
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
