Question about Vetta Cycling
Problem with Vetta bike computer
I have an older/simple model of a Vetta bike computer. No matter how closely I align the magnet to the spokes to register speed, I don't get any speed readout. It has a brand new battery and shows the display; just won't give me a speed readout.
Thanks!
3 Suggested Answers
wgjohnson
  • 3 Answers
SOURCE: Bicycle computer not registering speed
You can use almost any magnet with a speed sensor because they all 'register' a loop of the wheel with a magnet field sensor. The magnet must be no more than 8mm from the sensor to register the field. IF it is an older magnet, you might need to get it closer to the sensor. I always touch them, then move one or the other away just enough so they don't bump. Works every time. :)
Posted on Sep 05, 2009
  • 3 Answers
SOURCE: My Sigma BC 1106 bike
I had this problem as well. What I found was that the transmitter path from the magnetic sensor to the computer is very narrow, a 15 degree cone. Reposition your computer to fall within this cone. It should pick up the signal.
Posted on Sep 30, 2011
My cateye MC100W does not register anything in odometer, all other functions are ok
There is a small black sensor located on the bike frame immediately next to a wheel and a magnetic device clamped to a wheel spoke. They must be lined up close together. The magnet on the spoke sends a signal to the sensor as the wheel spins. The sensor counts the number of times the wheel is rotating.
Jan 10, 2015 | Cycling
Can the spoke magnet go on the rear wheel sigma bc 906
You should be able to use it on your indoor trainer. The Sigma will need a wheel diameter callbration to give correct readings.
Jan 29, 2013 | Sigma Bc 906 Computer
Hi, I'm inquiring about the Vetta RT55HD,
If its dead (blank screen) it won't work.
http://www.vetta.com/Tech%20Support/RTSeries/RT55HD-e.pdf
Maybe a new battery would be in order.
Mar 22, 2011 | Vetta RT550HDL
MY SIGMA 1009 COMPUTER SCREEN SHOWS 0 MPH WHILE RIDING.SEEMS AS THOUGH IT IS NOT TRANSMITTING ANY INFO. SOMEDAYS IT WORKS PERFECTLY.
You want to make sure the magnet on the front wheel is being picked by the receiver on the fork. Sometimes that magnet attached to the spoke will move on the spoke so that it no longer closely passes by the receiver. If the magnet has been lost, check with you can check with your local bike shop for an extra.
Feb 26, 2011 | Sigma Sport BC 1009 STS Wireless Computer
When i am riding the bike it is not telling me the speed
Some possible solutions:
computer unit is not "clicked in" to the handlebar mount. Remove it and re-seat it all the way in.
the spoke magnet and the pickup sensor on the fork are not close enough for a reading. Make sure that they are properly aligned vertically, and only about 1-3mm apart.
the battery in the unit is old and should be replaced. If you have a tester, you can check this. It will mean resetting the unit one way or the other. Replacement batteries are sometimes available at the "dollar" store.
sometimes the wire leads (if the Vetta RT55 is not wireless) into the handlebar mount become loose. They can be pushed back in, but this generally means the mount has to be replaced, if possible and economical, or the unit scrapped.
I hope this helps; good luck!
Nov 21, 2010 | Vetta RT55 10 Function Bike Computer
Hi The pictures in manual docent show the direction clear . The magnet and the trnsmiter.
magnet gets screwed or clipped onto the spoke.the transmitter attaches to the fork.make sure the magnet on the spoke passes the centre of the transmitter (should be a mark on the transmitter)and also make sure the magnet passes the transmitter with 3 to 4 mm gap.you may have to turn the transmitter alittle to get it closer to the magnet.hope this helps
Oct 14, 2010 | Sigma Sport BC1106 Dts Wireless Bike...
Where do I install the magnet cadence on my bike, the picture on the manual is not helpful. I have Cateye computer. Thanks for your help ~Ann
The sensor should be on one of the forks.
The magnet is attached to the spokes.
They should be positioned so that as the tire rotates, the magnet passes the sensor as close as possible without actually hitting it.
Zip ties and duct tape help with the minor adjustments and to keep wiring from getting rapped.
Have fun Mike
Apr 16, 2010 | Cadence Cat Eye Strada Computer
Cycling Logo
128 people viewed this question
Top Vetta Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Vetta Cycling Expert? Answer questions, earn points and help others
