Question about Mtd Garden
Mtd lawn mower trys to start as soon as i hook up battery
  • 376 Answers
Sounds like the starter solenoid is stuck in the start position. Tap it sharply and see if it still does it when you hook up the battery. You'll probably have to replace the solenoid.
Posted on Jun 20, 2009
Hose hook up for carburetor mtd 3/21 snowblower
one goes into the side of the carb. next to the engine, one goes into the air cleaner
Oct 16, 2012 | Mtd 22" Yard Machine Push Mower
How do I know which post is "in from battery" and "out to starter"? Thanks.
Just guess and hook up the two heavy wires. If it doesn't work, reverse them. You won't hurt anything. BUT---Make sure you have removed one cable from the battery (either one) before making or removing connections to the solenoid.
good luck
Jun 09, 2010 | Mtd Lawn Mower Solenoid Starter Replaces...
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
I have a model 13AH762F752 MTD Lawn Tractor on the front the bar that holds up the mower deck which way should it go in.? If you are looking at the tractor from the front R or L
if the mower deck is on the ground under the tractor raise the front of the deck up and push the deck towards the front u ntil the tabs are lined up with the hooks on the deck..good luck
Apr 06, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Mower will not start, battery cgarged up but onlhy
Check all the wiring connections on the starting system. Start at the battery. Both posts. Then, check where the ground goes to the body of the tractor. Make sure it's not rusty and making a good connection. Check the wire from the battery to the solenoid. If worse comes to worse, you can take a jumper cable and go from the battery + side and jump right to the starter post where an electrical cable connects. This will let the engine turn over, but make sure you have the mower in neutral and brakes set, with blades OFF!
Jan 28, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd mower blows fuse when you try to start it
Pull the starter and have it bench tested. If it is ok then you may have an engine timing problem. ''Good luck. donnyb60
Mar 23, 2009 | Garden
Garden Logo
140 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
