Question about GE JE1860 Microwave Oven
I have a GE JE 1860. Someone ran the microwave for 15 minutes with nothing in it. Now it doesn't work at all , no power, no lights, nothing. Is there a fuse that may have gotten burned out? Is this fixable?
  • jbasirico Jun 22, 2009
    Thanks> I did check for power at the plug and the outlet is fine. So Guess i just have to figure out a way to get the control panel off to check the fuse.
    J
  • 999 Answers
There is a fuse and cavity thermal fuses as well as one on the magnatron that is supposed to reset itself.. The fuse is behind the control panel and the cavity fuses will require removal of the cabinet. Did you check for power at the plug?
Eric
Posted on Jun 21, 2009
  • Eric Duda
    Eric Duda Jun 22, 2009
    If this is a OTR then there should be screws on the side of the console and maybe at the top. It then slides up and unhooks. Eric
We have a 10 year old GE microwave model JE 1860 and it turns on bit is loud and doesn't 't heat up wondering if it is worth repair or should we just replace it??
Carol, where I live the parts for what could be the possible problem and the labor cost for the repair would probably equal about 2/3 to 3/4 of the cost of a new microwave. Most dealers that I deal with in my area tell me that the average life span of a microwave is 5-7 years. Considering the age and what it might cost it might be better to invest in a new microwave. Hope this helps.
Jul 25, 2014 | Microwave Ovens
Hi. I accidentally ran my Maytag MMV4205AAW on high power for about 15 minutes with nothing in it. After I stopped it, it wouldn't come back on. No surface light - nothing. My circuit breakers are...
i personally do not recommend to a consumer to work on microwaves. they retain alot of voltage!
but will refer you here....
http://www.appliancepartspros.com/repair-help/maytag-microwave-mmv4205aaw-repair/mmv4205aaw-wont-start.html
Jan 14, 2018 | Maytag MMV4205 Microwave Oven
Microwave JE 1860 has been making a loud noise for several months. Today it quit. Nothing works. No light. Turntable does not turn. Nothing on the display ... not even the clock. The unit was purchased...
Unless your personally attatched to this oven I would recomend you start shopping for a new one. Take the cover off and look for any fuses inside the front door area or on the control board, If they are bad replace them if none there then get a new one as they are more expensive to repair than replace. Most likely your magnatron shorted out and took the circuit with it, but check your house fuse as well on that circuit to be safe. A magnatron runs around 90bucks part only.
Jul 01, 2011 | GE JE1860 Microwave Oven
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
GE Spacemaker Microwave not working
Hopefully not!. Microwaves have a failsafe circuit built in that when they overheat they shut dowen for about 3/4 hr in severe cases and then reset themselves.
By now it has probably come back on line.
Please rate my help++++Thankis for using FIXYA
Jun 12, 2010 | Microwave Ovens
My JE 1860 microwave starts working when I open the door.
It sounds like the door switch is bad. It may be that the switch is shorted inside. I would think it may really run with the door open, and microwave you.
Mar 06, 2010 | GE JE1860 Microwave Oven
We have a GE microwave model # JE 18600 SB 001 installed with a trim kit that stopped working. Can it be replaced with GE model # JEB 1860 SMSS?
You can download GE owner's manuals and installation instructions here. You can download for both models and compare the two.
Or you can ask GE Customer Support. Contact info is here.
But your oven may be pretty simple to fix yourself or with help from a friend.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit and symptoms) for free DIY help and information.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Power loss then surge GE JE 1860 Microwave
Well it does appear that you have an intermittent problem. I do not think that there is a loose ground problem, but there is a thermal switch attached to the case of the magnetron that resemble the thermal switches in wall gas heaters. Like the one in wall heaters they tell the heater when to shut off and on. If that switch begins to open or is trying to open it will make it seem like your microwave wants to shut down. Of course that is just one solution which I think is the best. By the way that thermal switch only has two wires that go to it and resembles an oversized watch battery when it is out. What could cause that also is if those two wires which are connected with plugin spade terminals have become loose due to the vibration of the magnetron over the years. To cover all your bases at once, with the power off, take the cover off and reseat all the spade connectors that you can see and get to. Anything in line with that switch or with the power coming in at all can cause the same thing. Let me know if there is any other question that you have.
Feb 09, 2009 | GE JE1860 Microwave Oven
Microwave Turn Table
This could be a failing turntable motor, but more likely your turntable support has gotten bent. That's an easier and cheaper problem to solve. Excessive heat can sometimes make the legs of the support bend so that the center is raised up far enough that it won't always make good contact with the motor. You can test this by running the microwave empty for a few seconds. It may hesitate to turn or stutter. Next try it with a bowl with several cups of water in it. The extra weight may push it down so it makes good contact and runs without a hitch. The way I fix these is to use a stove burner or a torch to heat up the legs and bend them up a bit. Then I quickly set up or clamp the support so it's held in the proper position for a few minutes until it cools. One way to hold the heated support in position is to place an object under the end of each leg and put something slightly heavy on top of it in the middle. If you need a new motor or just want to see helpful exploded views of your model, see the GE or Sears parts Web site: http://www.geappliances.com/shop/prts/ http://www3.sears.com/
Dec 23, 2006 | GE JES1851 Microwave Oven
GE JE1860 Microwave Oven Logo
296 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
