Question about Remington Smooth and Silky WDF-3500 Hair Trimmer
Replace Battery in Remington wdf 3500
I have removed the outside covers but cannot get the battery housing out
  • 30 Answers
"This however needs to be done by an Authorized Service Dealer."
Not true. A person with a modicum of capability can remove the battery and replace. It does require the de-soldering and re-soldering of the two battery tabs.
Posted on Apr 09, 2015
    New Friend:
It is more likely that the problem is the switch. It is poorly designed and tends to remain stuck partly in the on position, so when you try to charge it, the charger is supplying low power to the motor (not enough to run the motor) and over heats the charger. You can tell this by a dull charge light on the shaver. This can be fixed by dismantling it, cleaning the switch contacts and lubricating with an electrical contact lubricant. I just did this on my girlfriends and it's gone from dead to working perfectly. Do not use this in the shower, it is not made for this even if the manual says so.
Posted on Feb 24, 2013
  • 3 Answers
SOURCE: I need to replace batteries in Remington wdf 3500
Have just opened the same model -
First prise off the front and back "rubber" inserts - they should come unstuck quite easily. Then pull the bottom half of the case off the top half - it is held by 2 internal clips, one on either side of the inside black plastic casing - pull and wriggle and pull some more, and suddenly it will pop off.
Posted on Jan 31, 2009
  • 1739 Answers
SOURCE: How do you replace the
You can have the battery replaced. This however needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Posted on Apr 05, 2011
  • 1739 Answers
SOURCE: How do I replace a
  • 1739 Answers
SOURCE: How do I replace the
You can have the battery replaced but this needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
  • 1739 Answers
SOURCE: how to replace battery on
You can have the battery replaced This needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
I need to replace the battery in a Remington women's razor model wdf 1600
  • Open battery compartment
  • Note correct polarity and remove
  • Install new battery
  • Close battery compartment
  • Test operation
If the razor does not work, the replacement battery may be defective
Jul 12, 2016 | Remington Health & Beauty
Is my remington razor model wdf-3500 a wet and dry
The WDF-3500 can be used wet (with foam lather or soap) or dry when not plugged in. Turn it off when you put it under running water (when cleaning it for example). Do not have it near water when plugged into the charger.
Remington has the manuals for many of its products here: http://www.remingtonproducts.com/ConsumerService/UseCareManuals.aspx . Use the drop-down menus to get to your specific product. The direct link to the manual for the WDF-3500 in English is http://www.remingtonproducts.com/~/media/Files/Manuals/Shavers%20Womens%20Shavers/Remington%20Womens%20Shavers/English/WDF3500.ashx . (This is a PDF; you will need Adobe Reader or a similar product to view or print the manual.)
I hope this helps.
Sep 08, 2014 | Health & Beauty
How do I replace a battery on the Remington WDF-2000
Feb 21, 2011 | Remington Smooth and Silky WDF-2000...
How do you replace the battery in a remington foil shaver model wdf 6000
Jan 09, 2011 | Remington Smooth and Silky Ultra Plus...
How do I replace the battery in my Remington WDF 6000 shaver?
Dec 28, 2010 | Remington WDF-6000 Electric Shaver
How to replace battery on remington wdf 6000 ladies shaver
Nov 26, 2010 | Remington WDF-6000 Electric Shaver
Battery replacement Remington WDF 5500 How you you change the battery?
Sorry someone has not responded sooner.
Oct 09, 2010 | Remington Smooth and Silky WDF-5500...
Dec 22, 2008 | Remington Smooth and Silky WDF-3500 Hair...
Remington Smooth and Silky WDF-3500 Hair Trimmer Logo
1,312 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
