Question about HP Photosmart 2610 All-In-One InkJet Printer
All of a sudden I can't print a picture any suggestions?
I have a HP Photosmart 2610xi all in one & all of a sudden it won't print pictures. I have checked & all the cables are plugged in.
    President:
  • 1,564 Answers
You may need to install the driver for this printer. Try Windows updat(Hardware) or the cd that came with your printer and click "Repair" Drivers get shattered by Clean up apps and other reasons also try a system restore to an earlier date when it was working fine.
Posted on Jun 20, 2009
My HP photosmart c4280 all in one printer is saying "out of paper" when it isn't out of paper.
Hello Jodi,
HP disagrees with your "NO rear door"... assessment...
For your reading pleasure I am attaching YOUR
OWNERS MANUAL... Page 15:
HP C4280 Photosmart All in One Color Inkjet Basic Manual Clear Paper Jams
Look at the picture.
Hope this helps.
Carnac the Magnificent
Aug 12, 2017 | HP Photosmart C4280 All-in-One InkJet...
My HP 6280 will not print the full picture after it has been scanned. I put it in the right hand corner, chose the correct paper size and it still won't print correctly. Can you please help
Check corner marking for placing the document, place the document & scan through system, verify whether you got full scanned image? if not adjust the placement in correct position, once its OK, go for print there select correct image size(could be 100%) & paper size..I hope it will solve the issue..Best of luck
Sep 25, 2011 | HP Photosmart C6280 Printer
HP Photosmart 2610xi is printing but it does not keep the left margin aligned - it typically floats progressively to the right but sometimes wanders back and forth. Also about mid-way through each line...
You need to clean the encoder strip, that's the clear strip that runs behind the carriage assembly, you can clean it with a Q-tip damp with alcohol, the strip is fragile so don't press too hard. If you look with a flashlight you should see the area that needs cleaning.
Dec 31, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Printing on thin cardboard card - gloss finish HP Photosmart 4180
Sir,
You can try changing the way of your printing . I mean is do not print as Picture,but copy the picture ie screen as you feel easy and then past it on the the Microsoft word 2007 or any further version and than printer through it. print as page
Nov 06, 2009 | HP Photosmart C4180 All-In-One InkJet...
My Dad's 3210xi all of a sudden prints pictures in blues & greens
Occasionally printer cartirdges can clog and become unusable after refilling them several times. Also, if a printer cartridge has been "dry" for a long period it may experience the same problem. Your best bet is to buy replacement cartridges for any colours that show problems on the test page. If there is a blue & green hue to your printing that would suggest that the magenta is not printing and should be replaced.
Aug 23, 2009 | HP Photosmart 3210 Printer
Slow and deliberate printing on HP 2610xi Photosmart Printer
Resolving the problem HP has created a firmware update that will correct this and other problems. The specific problem corrected by the firmware update will be listed on the download page.
NOTE: Before installing the patch, the all-in-one software must be installed and the all-in-one must be connected, turned on and ready for another task. Follow the steps below to download and install the patch:
  1. Use the Support and Drivers Web page to locate the driver download Web page for your all-in-one.
  2. Select your Windows version from the listed versions.
  3. On the driver download page for your Windows version, locate the Firmware section and click the listed Firmware update.
  4. Review the information on the Firmware Update Web page and then select the option to download the file.
  5. Click Save to save the file to the computer.
  6. A Save As window will appear. Select Desktop in the Save in box, and then click Save .
  7. After the download is complete, close any running programs and verify that the all-in-one is connected to the computer and the power is turned on.
  8. Double-click the downloaded file on the Windows Desktop to install the update.
May 21, 2009 | HP Photosmart 2610xi All-In-One InkJet...
My HP Photosmart suddenly started blobbing out ink.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP Photosmart D7260 Printer
I need to no whats compatible to add my printer hp photosmart2610xi all-in-one
Step 1) Type HP.COM into the Google searchbox, and click on
to start the search.
Step 2) Once you are on the HP website:
Type HP PHOTOSMART 2610xi into the HP searchbox
and click on to start the search.
Step 3) You will then see a picture of your printer. Click on the
the first line beneath the picture, related to SUPPLIES
and ACCESSORIES.
Step 4) You will then see a list of products compatible with your
Printer.
Hope this info helps you out. Please take a moment to rate this solution, by using the rating system below. Thanks.
Jul 22, 2008 | Office Equipment & Supplies
Photosmart 2610xi Printing Problems
you might want to reinstall the latest and greatest driver from HERE uninstall your other printer and download the correct driver from HERE and install it on your system before you reconnect your printer... www.BigMoneyCentral.com
May 11, 2008 | HP Photosmart 2610xi All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
