Question about Kenmore 22422 Top Load Washer
How to make rinse cycle drain water?
IT WILL NOT DRAIN THE WATER FROM THE RINSH CYCLE
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Maytag clothes washer Model LAT6910AAW. leaks at the last cycle when the rinse water is drained. it may be the drain pump, except it doesn't leak when the wash water is drained (2nd cycle)
If your machine has a tray that you put softener in, softener is the last thing added at rinse time. If it is plugged or has a leaking supply hose, this would cause water paddles and appear to be related to the drain cycle.
Feb 17, 2017 | Maytag Washing Machines
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | GE WSXH208A Front Load Washer
Wont drain with cold water cycle
Need to reset the program and see if there is fault in the water line that does have a low flow and so the program cycle gets a error due to time taken for the rinse cycle.
remove and clean the inlet and the drain pump and hoses.
Jul 04, 2012 | Kenmore Elite Washing Machines
It will not drain the water on the rinse cycle
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 24, 2010 | Maytag Washing Machines
Drain washer pump for winter
Turn off the water at the cold and hot taps. Disconnect the hoses from the taps and the washer and drain them. Lay the drain hose flat on the floor to drain it to a container. With the hoses disconnected and the drain hose flat, start the fill cycle (set to WARM) briefly (15 seconds) to open the inlet solenoid valves and allow water to drain from them. Start the rinse cycle to pump any residual water out of the tub and drain (15 seconds).
OR
Turn off water and disconnect inlet hoses as described above. Pour 1 gallon of RV anti-freeze (for potable water systems) into the tub. Start the rinse cycle just enough to start the drain so antifreeze goes through pump and into drain hose. Before using the washer again, run a small rinse through to flush out the anti-freeze.
Nov 11, 2009 | Office Equipment & Supplies
My washing machine will not drain. It finished all the cycles but didn't drain after the rinse cycle. It still spun afterwards with water still in it.
Aug 10, 2009 | Whirlpool Washing Machines
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Rinse cycle
is the drain from the dishwasher in a syphon or runs into a free drain that air can break siphon cycle
or is drain up high enough eg 600 off floor be fore going into drain if not water will run in then straight out
Feb 23, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
Water wont drain
something is stuck in the drain pump axcess through front panel.
Sep 30, 2007 | Kenmore 44102 Front Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
