Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
Changing the blade to our compound miter saw when hex slot is rou
The blade bolt on our compound miter saw will not loosen and the hex wrench that came with it is rounding out the opening. What do we do now?
  • 285 Answers
Ok a couple things to try...
Firstly to hold the blade arbor still if it doesnt have an arbor/spindle lock button, try wedging a piece of wood between the blade and the saw table (might have to lower the cutting head and hold it down. Next try again with the hex key... Make sure it is the right size one, i.e. the one that came with the saw. If the hole is really rounded out, you are in a bit of a bind, however, the next option is to get a grinder and try and slice a groove across the nut so you can fit a large screwdriver or a flat piece of steel in th slot in the nut you just made for leverage and try and work the nut off that way. Either way, be sure to get a new blade nut if and when you get it off to make sure the problem doesn't occur again. See how you go.
Posted on Jun 20, 2009
Recalibrating the angles
look on top of fence
see 4 holes
loosen 4 bolts (probably hex wrench) and fence will loosen also
framing square against loose fence and lowered blade (to calibrate square)
tighten fence,... square to blade
Jan 15, 2011 | Makita 10" Dual Slide Compound Miter Saw...
I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE BLADE, BUT I'M NOT SURE EXACTLY HOW TO REMOVE THE BLADE GUARD. I KNOW THAT I NEED TO PURCHASE THE CORRECT BLADE WRENCH TO DO THE JOB. CAN YOU TELL ME THE...
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Dec 31, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Lost my manual. Need to know how best to switch blade
There is t shaped scocket type wrench that came wuth the saw that pushes into the saw next to the rear handle it fits the bolt that holds the blade on.There is l shaped metal locking buttom on the front of the motor houseing. The bolt has left handed thread so it loosens in the oppisite deriction as a normal bolt clockwise. push the L shaped button in to lock the blade loosen the bolt remove the washer and blade install new blade in reverise order
Dec 22, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
How to change a blade in miter saw
There is a button on the saw near the axis the blade spins on push the botton there should be an allen wrench that is supplyed with the saw that is mounted or stuck or attached to the saw this fits the bolt that secures the blade the bolt that holds the blade turns left handed so most bolts turn righty tighty lefty lossey this is oppisite turn it clockwise to lossen it
Dec 03, 2010 | Makita LS1013FL 10" Slide/Compound Miter...
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
I have 1 10 In compound miter hexbolt will not loosen and lock will not hold. Is it possible that the bolt is a left thread?
most mitre saw bolts that hold blade are left hand thread. If you overtightened you might have to use extra force to loosen, on occasion I have had to use an impact wrench to loosen.
Jul 13, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How do i change the blade on a bosch 3912 chop saw
Push the saw down and manually hold the guard while it is the retracted position and let up on saw while holding guard,you should
be able to put in wrench and loosen bolt.
Apr 09, 2009 | Bosch 3912 12 Inch Compound Miter Saw,...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Mitre saw won't cut square
You will have to use a regular square to check out the crafstsman and find out where it is wrong.
Jan 16, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
268 people viewed this question
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
