Question about Yamaha 12V Air Pump
I have a side mount starter that has no power to it.
The 50 horse Yamaha motor ran great. Went to start my boat (side mount console) again today and have no power whatsover. Battery is fully charged. Terminals and wiring look fine. Is there an in line fuse or a reset button somewhere on the conssole, in the console, on the motor? Does anyone know how to test where the electrical outage may be happening?
Thanks for your help!!!!!
    Champion:
  • 207 Answers
There may be one next to the battery in a little blacksquare pulg on the motor as well there will be two or three look near the starter for little black cylinder (rubber) or little square plugs (plastic )
Posted on Jul 08, 2009
What is the maximum engine size that I can put on my 1994 Sun Spa 200 pontoon boat?
Look for the Manufacturer's capacity plate. It will specify how many persons the boat can safely hold and the maximum horse power rating. It can usually be found around the transom (back of the boat) were the motor is mounted or near the steering console.
Jan 15, 2018 | Boating
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
I need to know the ratio of a gas and oil mix for a 1999 yamaha outboard motor 90 horse power already broke in...
I'am amazed it doesn't have an oil premix that gives it auto oil mix.If it doesn't than the mixture is 50/1.That is fuel /oil ratio.e.g. 50 litres of fuel to 1 litre of oil.Hope this helps
Apr 17, 2010 | Boating
I own a 1994 boston whaler Rage with a yamaha J650c jet drive in it. I bought this boat and the temperature sender was not working. I replaced the gauge and the sender . The sender goes into the computer...
boston walyler and a yamaha j650 is a good set up
all you need at the moment is a led test light and a volt meter
make sure you have volts or amps and earths at the right places
some messy DIY wiring done and takes time to sort it properly
i would suggest a compression test on the motor
you have water pump impeller worn or coil ,plugs, fuel supply and other reasons why the motor would over heat or run rough
no temp shut down system on yamaha electronics module
if that was blown the motor would not start
this is the boat and the motor yamaha J650c
Mar 04, 2017 | Sport & Outdoor - Others
I have a 90 Horse power Mercury outboard Boat motor on a skeeter boat and the startes cylinoid is just making a clicking sound but the motor won't start . Do you think it could be the starter?
Sounds like the starter. Check if you have power at the solenoid from the battery with just the power on (key turned on, power switch on.) thats good-- you have power-- if not you have a wiring problem from your battery or main switch.
Otherwise you have a starter problem probably.
May 14, 2009 | Boating
No acceleration
I'd be checking fuel flow. Usually if you have to choke or squeeze a primer bulb to keep it going, the motor isn't getting enough fuel. Check all fuel lines and connections are air tight, then if problem persists, investigate fuel pump.
A good carburettor cleanout and new carb overhaul kit wont hurt either.
Feb 28, 2009 | Light Outboard Motor Boat Bass Fishing...
Yamaha 12V Air Pump Logo
83 people viewed this question
Top Yamaha Water Sport Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
