Question about Cosmi Greeting Card Magic for PC
Can you help set up?
When I put the software in the CD-ROM drive, nothing comes on the screen.I hit start, then run.Then, I'm lost! Can you walk me through the setup?I could not find CDSETUP Oor the EXE.
  • 233 Answers
Is the CD ROM recognized in 'My Computer'?
Are other CDs able to run?
If not, ununstall CD ROM drivers, shutdown and restart, CD drive should then self install.
You can update ALL your drivers with this new program.
versiontracker Pro $29.95
"Keeping your software and drivers current helps keep your PC running smoothly, but locating and matching the right updates for your machine can be frustrating and time-consuming. With versiontracker Pro, you don't need an IT department. versiontracker Pro scans your hardware AND software to determine the right updates for your drivers and applications."
(Quote from website)
Posted on Nov 05, 2007
How do i restore my hp pavilion dv 5000 to factort setting?
There should have been a recovery disk created or included when you bought a laptop. Insert disk if you have it and restart your computer with the recovery disk in the CD drive. Make sure all your documents and personal data are backed up. When the computer restarts it should start restoring your computer to the factory default. There will be a wizard to guide you through the process.
If there is no disk or got lost,then follow this steps:
1.Save any files or folders on your computer with flash drives. Drag and drop files onto the icon of your flash drive.
2.Go to "Start" > "Restart" to reboot your netbook.
3.Hold down "Alt" and "F10" when you see the logo on the screen. The recovery menu will load.
4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your computer back to factory settings. Follow the instructions on the screen.
5.Choose your time zone and language when the customization menu appears. Reboot when you are prompted.
6.Restore your saved files from the flash drive.
hope this helps,Goodluck..pls response with your rate and testimonials below for further issues..thanks
Feb 23, 2011 | Computers & Internet
The Installation CD Does Not Start Automatically in Windows XP
This tip answers issue regarding CD's that come with your HP printer. <span>If after putting the installation CD into the CD drive, the software does not automatically start installing the software you can do either one of the following.</span> <span>1. On your pc, go to Start, click My Computer, right-click the CD-ROM drive then click Autoplay.</span> <span>2.If nothing happens, check whether the Autorun feature is enabled, if not enable <b>Autorun</b> by going to t</span><span>he <b>Control Panel</b>, double-click <b>System</b>, go to <b>Device Manager</b> and click the plus sign next to CD-ROM Drive entries. Right-click the name of your CD-ROM and go to <b>Properties</b>. In the<b> Properties</b> screen, go to <b>Settings</b> and check the box next to <i>Auto Insert Notification.</i></span> <span></span><span>Or</span> <span>Click <b>Start</b>, then <b>Run</b>, type <span>gpedit.msc.</span>Click <b>Administrative Templates</b> under <i>Computer configuration</i>. Click <b>System</b>, then click <i>Turn off Autoplay</i>.Right-click <i>Turn off Autoplay</i>, then click Properties. Under <b>Setting</b>, click <i>configured</i>.</span> <span>3. If any of the two won't work you can manually install the HP software CD. To do this, c</span><span>lick <b>Start</b> and then click <b>Run. </b></span><span>Click <b>Browse</b> and then select My <b>Computer</b>. </span><span>Click the CD/DVD drive. </span><span>Double-click the <b><u>setup.exe</u></b> file.</span><span>If nothing happens, it may be because CD drive is unable to read the CD.</span> <span>4. Check whether the CD drive is working by playing other CD or DVD.</span><span>If music CD/Video CD is not working then there is an issue with CD/DVD drive, contact Computer manufacturer.</span><span>If the Music/Video CD works with the CD drive, clean the HP software CD using a soft cloth damped in distilled water and wipe the CD with lint free cloth.</span><span>Reinsert software CD and wait until it auto plays.</span><span>If it fails again then try inserting software CD in a different drive if any.</span> <span>5. </span><span>If CD is not working in any of the available drives then copy the files to the hard drive.To do this,c</span><span>lick <b>Start</b> and open <b><i>My Computer</i></b> or double-click <b>My Computer</b> on the Desktop.</span><span>Double-click <b>C:\</b> or <b>D:\</b> , assuming C: and D: are the computer hard drives.</span><span>Right-click the empty pane in C:\ or D:\ of <b><i>My Computer</i></b> and select <b>New</b> .Then click <b>Folder</b> .</span><span>A new folder is created. Rename the new folder <b><i>HP Driver</i></b> .</span><span>Right-click <b>Start</b> and then click <b>Explore</b> to open Windows Explorer.</span><span>Locate the CD-ROM drive letter in the left pane of the window and select it so that the contents are displayed in the right pane.</span><span>Click <b>Edit</b> in the <b><i>File</i></b> menu and then click <b>Select All</b> to highlight all of the files and folders.</span><span>With the files still selected, click <b>Edit</b> and then click <b>Copy</b> .</span><span>Close Windows Explorer. Open the HP Driver folder created in step 1, click <b>Edit</b> , and then click <b>Paste</b> to copy the files to the HP Driver folder on the hard drive.</span> <span><br /></span> <span></span><span>If while copying, a <span>Cannot copy from source disk or drive</span> or <span>Cannot copy specified file</span> error message is displayed, then check the functionality of the CD drive by using a different CD. </span> <span><br /></span> <span>If other CDs work correctly, it means there is an error reading the HP software CD.</span> <span><br /></span> <span></span><span>If the files cannot be copied from the CD, the CD may be defective. In this case, you can either download a software or order a CD at <u>support and drivers</u> page of</span>
on Apr 03, 2011 | HP Officejet 5610 All-In-One InkJet...
Cannot get computer to reconagize printer the software disk is not loading
You can download the software from the companie's website. You should also download the latest drivers, then double-click on them to install them, restart computer and be good to go.
Sep 10, 2009 | Computers & Internet
Cd-rom does not come up
Open My computer on your PC and double click on your CD rom drive and run setup or install from there.
Jun 25, 2009 | Ulead Videostudio 8 for PC
Cannot get CD-ROM to work,to come up on screen.
Ok with that you need to insert the disc and then go into the my computer section of your computer and then in the CD rom drive you should see the disc and you will click on it to start the process. However if that does not work then your CD rom drive is defective and you need to purchase a new one.
Jun 17, 2009 | Computers & Internet
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
My pc was doing this but now it's doing something different but simular
Try telling it to boot the CD instead of the disk for now, since you need to install from that...or perhaps a newer OS.
Jun 23, 2008 | E-Machines eMachines T3830 PC Desktop
Lost everything
sorry to say,but please re-install your operating or repair your windows from windows 2000 cd ensure problem do not persist download trial version of the software IOLO SYSTEM MECHANIC or some other registry repair software and run it on your pc.
Mar 01, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Instructions wanted
Put the CD ROM in the CD Drive. Wait for the autorun to start and click "Install". Follow the rest of the on-screen instructions. If when you put the CD in and nothing shows up after a minute or two, then go to START > My Computer. Doubble-Click on "D:\", or whatever drive the CD is in. If it takes you into the CD files, find a file that says "autorun.exe". If you can't find that, try finding a file that says "setup.exe". Double-click that, and then follow the on-screen instructions.
Feb 08, 2008 | Computers & Internet
Windows XP Unsuccessful on Start Up
no you just need to fix your bios problem, if you dont have the manual take the battery out of the motherboard that keeps power to the bios keep it out for a few minutes put it back in then turn it on it should go to bios automatically then just go to set best defaults for ststem hit y for yes then hit enter and it should take off fine if it dont then you need to take it to a pro who can reset it for you manually or reprogram it that would be cheapest for you without trashing it.
Dec 30, 2007 | Acer Aspire 3000 Notebook
Cosmi Greeting Card Magic for PC Logo
105 people viewed this question
Top Cosmi Computers & Internet Experts
Alun Cox
Are you a Cosmi Computer and Internet Expert? Answer questions, earn points and help others
