Logitech Cordless Mouse Logo
Posted on Jun 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wireless mouse batteries needs to be recharged every 4 hours
When mouse is not used should batteries be automatically disconnected? How can I do that test?
Alex Howard
Level 3:
  • Master 484 Answers
  • Posted on Jun 20, 2009
Alex Howard
Master
Level 3:
Answers
484
Questions
Helped
124118
Points
1243
In general, unless you plan to not use the wireless gear for a very long time, you do not need to remove the batteries. A week or so is not a big deal. Months, however, is and you can find the batteries corroded if you leave them in for too long. Check them every month or so, just to be sure.
I have hp mini 210 laptop. I connect usb dongle of optical mouse to laptop. It installed automatically & successfully. It showing in device manager (Human interface device) but still optical mouse is...
Welcome to FixYa!
Here's a quick checklist to resolve your wireless mouse connection.
Solution 1.
1. If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2. Make sure that the battery of the wireless mouse is placed correctly and is not drained.
3. After checking the first two steps, the optical lens on the underside of your wireless mouse should be flashing once in a while. If not, there is something wrong with the battery, the wireless mouse switch, or the wireless mouse itself is defective.
4. Connect the USB dongle in the USB port and let it install automatically.
Solution 2.
5. Connect the USB dongle in another USB port and let it install automatically.
Solution 3.
6. Restart the computer with the wireless mouse turned on and the USB dongle inserted in the computer.
Solution 4.
7. Download and install the drivers from here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-47909-1
I hope that this will help.
Thank you for using FixYa and keep me posted!
Jas247
How to replace battery of wireless laser mouse mi
On the Top on the Mouse u can see the Battery u need to Remove the old Battery's and Replace with New battery see that you use Rechargeable battery because ordinary battery life spam is very less and u need to change the batterys for every 1 month so if u use the rechargeable battery then u need not change battery for 1 month at least for 5 or 6 months the rechargeable battery work and u can keep and spare rechargeable battery when every needed and try to purchase a Sony Rechargeable batterys deepakkumaar.jpg
Only a few hours after inserting a new battery (tried two different packs of NEW batteries) into my Microsoft 6000 wireless mouse, the red light on top comes on.
I use rechargeable batteries rated at 3200MAh and have been operating for 2 months now.
If you can't get hold of them, try fresh Alkaline batteries like Duracell.
pls. vote for better service... thank you
Mouse works fine when cord is in it but when it comes to wireless the mouse does not last long. How long should I charge the mouse with the batteries in it plugged to the computer?
Rechargeable batteries do expire after a while either get new ones or get a battery tester to see how much life they have left. under normal circumstances a new set of batteries last me about two weeks before i have to recharge them and my computer stays on 24/7 including the mouse with at least 5 or more hours of use per day.
1helpful
It uses up two AAA batteries in less than four hours of use!!
Hello Pabobr, hi, I wish this may help, I want to ask you a question, during that 4 hour use, does your mouse operate normally?
If yes, then thats a design problem, If no, you need to try other battery makes, and see if the changing battery names with solve your problem, if by any chance the problem still persist, try you mouse on another PC, see if the problem is your PC or not, if still you cannot break the 4 hour use, its already a design flow of that wireless mouse, call your dealer if what you have experience is the true just for confirmation. Try also other brands, you choose, still continue to use that mouse, and waste money on batteries or try other makes. Or go back to the traditional wire mouse.
1helpful
CE0682 logitech mouse
"Normal" batteries are 1.5 Volts per "Cell" However Ni-Cads, rechargeables, each "Cell" is only 1.2 Volts. So the rechargeables simply may not work... If they do work, then there is NO reason why not.
2answers
I replaced the rechargable batteries in my logictech wireless mouse and put on the charger for 8+ hours - my mouse still does not work. what else can be wrong? It is frozen in the middle of my screen.
You may want to try with normal batteries instead of the rechargeable ones.
You have not provided the model no of your mouse. Is it connected to PC or laptop?
Are you able to go to the logitec mouse setup in control panel and check if the diagnostic works.
Some wireless mouse devides have a reset button which you sync with the base unit that goes to the USB port. If this one has it, then try to resync.
Waiting for your responses so that we can diagnose the problem further.
The battery is dead
what happens if you put the mouse on the charger and leave it there for 2-4 hours?
Does it recharge?
I supose you could replace the recharable battery yourself by opening the mouse and so on, but finding the right type of a battery for it might not be as easy as that. Id recommend takeing it to warranty repairs if it still has such.
Other options would be to buy a new mouse.
2answers
Wireless mouse
u need to get the wireless kit replaced
4helpful
2answers
Changing the batteries on the BenQ Wireless Mouse
If you slide down (hard) the panel beneath the 2 clicker keys, you will find a battery compartment with space for 2 AAA batteries7f60d17e-8b58-4076-acc1-563ab4428c0d.jpg
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
