This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
SOURCE: ps3 will not turn on
Your playstation is oficially broken and needs to either be replaced or repaired. Sony will fix this problem for $150.00 through their website(under warranty its free). This problem happened because it overheated and the soder melted to the point where the componets shut down and the unit went into safe mode :( :(
SOURCE: my ps3 won't release game out of console get yellow light
If you turn your ps3 off in the back, then hold down the eject button while you turn it back on it should come out, your welcome. j/k but it did work on mine.
Testimonial: "i got it out thank you for help!!!"
SOURCE: My PS3 has a flashing red light, when I turn it
Hello there baileys 946 If you have the brief
flashing yellow light, then its followed by a red blinking light then
you have the yellow light of death AKA the YLOD. The lights are a
warning sign to let you know something is wrong. I can give you the
quick explanation, There are 2 chips on the motherboard inside the
PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the
solder heats up and when you finish playing it cools down, over time
this will cause the soldering to crack and the chips to lose
connection with the motherboard and you get the YLOD. WHERE TO GO FROM
HERE Option
1 - Call Sony In warranty the Price
is Free, out of warranty the Price is $150,
the whole process is 4-6 weeks You can call Sony and
they will collect the PS3, repair/replace, and deliver the PS3 back
to you Option
2 - Fix it your Self You can use a PS3 fix
manual to get this fixed easily and at home using household tools you
probably already own. Click
here to know more on PS3 Fix Manuals which has helped so many
people like you. Good luck Best regards Peter
SOURCE: when i turn on ps3
We work with these issues all the time, it is called YLOD. A Chip gets separated from the mother board causing it to shut off with a yellow light and 3 beeps after that. in order to repair that you must send it to sony or find a local repair shop that works with ps3.
Thanks
www.1RepairStop.com
Hello there corbie dadd
The lights are a
WHERE TO GO FROM
HERE
Option
1 - Call Sony
to you
Option
Click
people like you.
Good luck
Best regards
Peter
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
