Question about Samsung Syncmaster 940BW LCD Monitor
Samsung sync master 940 bw white screen
My samsung sync master 940 bw only shows a white screen when plugged in. i have tried plugging it in to several computers and both linux and windows. the buttons do appear to work however the menu do not come up. can you please help me
Fix-4U
  • 293 Answers
SOURCE: Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Posted on Oct 11, 2008
  • 225 Answers
SOURCE: i cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
Posted on May 28, 2009
  • 1684 Answers
SOURCE: Start up problem with Samsung Sync Master 731BF 17" monitor
Your internal power supply is failing. There are parts called capacitors that are not functioning correctly and this causes the power supply to not be able too stabilize the voltages that run the monitor. After repeated power cycles the capacitors will hold enough charge to function until you urn the unit off and then they discharge so you have to start all over again. We have a step by step repair guide article posted at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ This should get you back going again. If you don't want to do the repair yourself we do offer a repair service, you can get that information here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Apr 29, 2010
  • 1684 Answers
SOURCE: On every start up, my Samsung screen
The slow startup is an indication that your power supply board i failing. The board tries to power up but the voltages are not stable so it shuts down and retries over and over until they do level out and you get a picture. This will get worse until it dies all the way and you get no power at all. The repair involves replaceing a few parts on the board. If you can solder then you should be able to do the repair yourself. We have an article posted here that shows what needs to be done: http://www.ccl-la.com/blog/index.php/service-request-form/ The 731 uses the same power supply board as the 720. If you don't want to do the repair yourself we do offer a repair service, here is more information on that: http://www.ccl-la.com/blog/index.php/service-request-form/
Buddy
Corporate Computer
www.ccl-la.com
  • 80 Answers
SOURCE: Screen don't work when plugged in
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
Dual samsung sync master s27a350h monitors
Hmm. Maybe your graphics card or RAM can't cope with both? Try showing usage on Windows Task Manager (CTRL+ALT then DEL)
Feb 23, 2014 | Samsung LCD Monitors S27A350H SyncMaster -...
My samsung sync master 151 -s screen is completely black, The rest of the pc opereates fine. The screen was working fine, then left to idle for a few hours now it appears really dark.
Try turning off the power to the monitor and the computer, check all the cables and power it all back up again. If the monitor is still black, try plugging it into another computer or into a laptop and see if it works there. If it does work, then the problem is the video card in the computer. If it is built into the mother board, then you can disable it in the bios setup and buy a PCI or AGP video card on eBay to plug into *********** board.
Nov 18, 2010 | Samsung SyncMaster 151 N 15" LCD Monitor
Why my display show plug and play monitor instead SyncMaster 732nw?
U NEEDS TO INSTALL MONITOR CD COMES ALONG WITH MONITOR. THEN IT SHOWS SYNC MASTER. AND THE COLOR SETTINGS WILL BE ALIGNED AUTOMATICALLY.
Apr 17, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
The screen flick when connected to Samsing Sync
Hello there!
Screen flickering can be caused by instability of cable you are using, or it can be also caused by difference between power input, so check your power plug ,where your monitor and pc are plugged, make sure they are ok for your region, and check those cabels. Also check settings on monitor for what input you are using DVI or VGA or both at the same time.
Sinecerly
Aleksandar Adzic
Apr 16, 2010 | Computers & Internet
I have a Samsung Sync 223 BW monitor and the screen today has been blurry it happens every now and again but today has been particularly bad, how do I get rid of it???
Samsung Sync 223 BW open it find the plybac there are two switch there for the screen focus turn it with a screw until the screen is ok then apply glue to fix it.
Mar 17, 2010 | Computers & Internet
How to unlock OSD Lock
To get rid of unlock message on samsung sync master 753s,open the back cover.just unplug the white 12 wire plug near the fly-back transformer and plug half way and re start monitor.Do it while it is working if you have some experience and courage . cperera01@gmail.com
Feb 01, 2010 | Computers & Internet
My syncmaster 245 bw will only display a blank screen through the dvi port. Another crt monitor works fine through the vga port . I'm running a nVidia 7800 GS video card.
You need to adjust the monitor refresh rate to 60 Hertz or 70 Hertz.
Use the CRT first to adjust it, then after adjust,plug in your Sync Master to see is it perfect or not,find the best frequency that work best.
To adjust it,right click on the screen,enter properties, then click setting tab.
Then in advanced tab, click it then you see the monitor tab, find the perfect screen refresh rate.
Dec 10, 2009 | Samsung SyncMaster 245BW Monitor
Hi...there,
Oct 09, 2008 | Samsung Syncmaster 940BW LCD Monitor
Washed out text
Monitors have brightness and contrast setup on them usually in a menu. A lot of monitors have a 1 button self correction that may work for you also
Apr 01, 2008 | Computers & Internet
Open Questions:
See all Samsung Syncmaster 940BW LCD Monitor Questions
Samsung Syncmaster 940BW LCD Monitor Logo
703 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
