Question about Kenmore Washing Machines
Agitator? Spinning? Agitator start right away when machine start, in another words, water and agitator working at the same time, when finish spinned, clothes are still soaked.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Fills with water but then does not agitate. Agitator moves only tiny bit in both directions. Pumps out and spins OK but makes grinding sound when finished spinning
I do not work on washing machines, But I had the same problem with my own unit. Replacing the transmission fixed it. I hope this helps you.
Mar 07, 2015 | Washing Machines
Why is the agitator not working or not spinning?
Here are a few problems, The lid switch may be bad ( to check it )Raise the lid, find the switch. remove the 2 wires from switch and tape them together, but do no let them touch any steel or you will get zapped. If the agitator works fine, The switch is bad. #2 drive coupling on motor to agitator is bad, #3 clutch is bad, Check out the switch first. If the lid switch is bad it will not send current to start the motor ( safety precaution ). Good-Day!
Aug 29, 2014 | Kenmore Washing Machines
Its spinning but the water is not draining away and the clothes are still wringing wet
This usually indicated a problem with the pump. There is a belt which turns the agitator, spins the drum, and turns the pump, which is what removes the water. Since the agitator works and the drum spins, the pump is probably faulty.
Aug 02, 2013 | Indesit W 123 Front Load Washer
Agitator not spinning
agitartor stripped
you can order the dogs at sears
agitator dogs
Oct 04, 2009 | Washing Machines
My washing machine is spinning and agitating at the same time no matter what setting it is on.
Seen it. Replace tranny. Good news: tranny is pretty easy to swap out. Remove the agitator and the 3 screws to that tranny and it slides right out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 15, 2009 | Washing Machines
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Transmission problem
it sounds like a GE or Hotpoint washer. if so the transmission is bad and i would replace the machine. transmission is $175+
Jun 29, 2008 | Washing Machines
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
could'be water level switch or timer control. another posibility is corrosion on the motor wiring connector
Jun 22, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
20 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
