Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
Frigidaire commercial upright model no. LFFU2065PW2 Does not freeze took back inside panel of fan is working but the condensor is freezing up. 4yrs old, compressor seems to be working. thawed it out left back panel off plugged back in fan worked but it started freezing back up.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 15, 2010
My upright frigidaire freezer won't cool. Lowest temp it goes to is 1 degree. Fan works. model number is Ffh17f7hwj
Remove back plate and check to see if evaporator is frozen over. If so, your defrost timer/heater is not working. Till repaired defrost unit completely. It will work fine till it freezes up again or you make the necessary repairs. Not hard to do just a PIA.
Sep 15, 2017 | Frigidaire Freezers
My freezer is heating up?
Because a freezer only does one thing and that is freeze things, unfortunatly any things that breaks on a freezer causes the same thing. Is it running, does the fan work (frost free) are the shelves melting (non frost free) can you hear the compressor running , is the condensor fan running ?
Aug 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
It won't freeze, fan blows but won't freeze
dear sir /madam
please check in your freezer,s back side there is compressor please try to find it,s running or not if it,s running and it,s not getting cool and not freezing inside then it can be low refrigerant gas problem it,s up to you ,refill the gas by yourself or take help to a technician.
hope answer the question
thank you
please vote!
Sep 13, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Top half does not freeze
There is a fan behind the back wall of the freezer about 1/2 way up from the bottom, you should be able to hear this running when the freezer is on. If you do not hear this then you need a new evaporator fan motor.
If you hear the fan run then you most likely have a problem with the automatic defrost cycle that would most likely be the heat element that is located just below the coils inside the freezer behind the panel.
Apr 21, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Freezer is running but the items are thawing and not freezing
it could possible be the defroster unit going out on the thermostat theres a hole on the bottom where you can access a screw that will allow you to check and see if the defroster is working put a srew driver in the hole and turn it clock wise till you here it click and then listen for the unit to start defrosting cycle you'll hear a hissing like sound if its working if not you'll need a new defrosting unit
Jul 09, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
103 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
