Zenith D52WLCD 52 in. Rear Projection HDTV-Ready Television
Problem for Zenith D52WLCD 52 in. Rear Projection HDTV-Ready...
The tv has shadow of red and green about 10 inches
By loisandcliff on Jun 20, 2009
the tv has shadow of red and green about 10 inches in on both left and Right sides. Center is still ok?
Solution #1
posted on Jun 21, 2009
Not Rated)
Ecollier2012
Rank: Guru  Televisions & Videos  Expert
Rating: 93%, 576 votes
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
Popular Solutions for Zenith D52WLCD 52 in. Rear
Questions and Unsolved Problems for Zenith D52WLCD 52 in. Rear
Do you recommend Zenith D52WLCD 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes... (More)
Answer
I have a 65 inch 1080. We moved yesterday and when I turned tv on it shows red on lamp button, tv... (More)
Answer
tried the solution to reset the lamp counter on my d52wlcd zenith tv but but nothing happens. No... (More)
Answer
replaced bulb and still have yellow glow and blue dots in center of screen
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
