Question about HP Photosmart C6280 Printer
How do you set the number of copies you make on the copy menu
    President:
  • HP Master
  • 1,996 Answers
Instructions here and main support page link here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 20, 2009
How do I get phone numbers to sin card ?
A "sin" card would be awesome, but I'm sure you mean the "sim" card! Every phone has its specific procedure for copying contact numbers to the sim card. Some do this by default. Some must have a setting selected. Most have a very simple way to select individual contacts to be copied to sim, from the "context menu" - press the button or key that displays the symbol with three horizontal lines. Note that sim cards have a set limit of the number of contacts that can be copied: if your contact list is large you may only be able to copy some of them. This limit will also apply to defaults chosen in settings. When the limit is reached copying will either cease or existing contacts on the sim will be overwritten. There will probably be no indication when the limit is reached, so you won't know that contacts are not being copied or overwritten. In other words, the sim contacts may be incomplete, so don't rely on this method for backing up your large contact list.
Jul 28, 2014 | Samsung Galaxy Y GT-S5360 Factory Unlocked...
On the display access cod
Enter in the User mode set menu screen 6/6,touch the Copy Track.Used to turn ON or OFF the copy track function per account.When ON is selected press the Enter key.Press the UP/DOWN key to acces the Account#to be administrated.Press the Acces#key and register the acces number corresponding to the above Account# from the 10-key pad(max.4digits)If the access number has been changed or the number entered is wrong,press the CLEAR key to clear the number and re-enter.Press the ENTER key to enter the access number.When the copy is to be made after the acces number has been entered,the access number must be entered and the access# key pressed to enter the copy mode.Factory initial setting to Copy track mode is OFF.
Jan 03, 2013 | Minolta EP4000/5000 CS/PRO Copier
What do you mean by "stack copies" in brother
Sorting copies using the ADF
You can sort multiple copies. Pages will be
stacked in the order (1, 2, 3), (1, 2, 3)
and so on.
1 Press (Copy) to illuminate it in
green.
2 Load your document.
3 Use the dial pad to enter the number of
copies you want (up to 99).
4 Press Options and ? or ? to select
Stack/Sort.
Press Menu/Set.
5 Press ? or ? to select Sort.
Press Menu/Set.
6 Press Start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 28, 2011 | Brother MFC 7420 All-In-One Laser Printer
Can't find copy menu to take a copy of an address
May i know the printer/ copier model number to assist you better ?
The general rule is, If your printer is a Color printer, then it should have a button/option for COLOR copy.
If it does not have a button/option for Color that means it prints only in black.
Jun 13, 2011 | HEWLETT-PACKARD Hp Ac Adapter Power...
How do I print several copies of a page on my HP 3015 printer
when you click on print, you should normally get a print window where you can indicate the page to be printer and the number of copies before you proceed with the print job.
Dec 31, 2010 | HP LaserJet 3015 All-In-One Printer
How do I save my phone numbers from my SIM to my
Problem can be solved.
Go to the menu of the phone, you will see contact menu, click on it and scroll down you will see settings, click on it and scroll you will see copy from phone to Sim card, click on it and it will ask if you want to copy one by one or copy all.
If you wan to copy all click or if you want to copy one by one you can click. i think that will help.
Take care.
Mar 18, 2010 | Samsung SGH-C120 Cellular Phone
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
HP 4 Plus printing same job multiple times
I'm not an HP user but try this.
Does this work with all programs (e.g. when you try to print a page from Google) or does it happen only when using your word processing program? Which program are you using?
When you tell it to print one page there is generally a place in every word processor that will allow you to tell it how many copies you want. Make sure that setting is correct. Check your default settings as well to ensure they are set to one page.
If you don't know how to change the number of copties, go to your help setting in the program and look up "copies"
Also check your hardware setting on your printer to make sure you don't have it set to 5 copies.
Sep 25, 2009 | HP LaserJet 4 plus Printer
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Getting more copies at once
In almost any windows application there is a command in the FILE dropdown menu that is labeled "Print..." It's usually right above "Print Preview". To print multiple copies click "File" then click "Print..." and you will get the following Windowa63a80c.jpg Just select the number of copies you want by clicking the up/down arrows where it says "Number of copies"
Dec 19, 2008 | Office Equipment & Supplies
HP Photosmart C6280 Printer Logo
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
