Question about HP Photosmart 7850 InkJet Printer
Paper feed is malfunctioning
Printer will not take the paper to print. Makes a clicking sound as though it were stripping a gear.
  • 508 Answers
Check to see if there is not anything stuck in there? hold up printer and shake carefully,also clean with alcolhol and can air!hope this helps!
Posted on Jun 20, 2009
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
When paper is fed into the auto sheet feed the left side of the paper feeds, but the right side is not feeding at all....resulting in a paper jam. You can hear the printer printing but the paper doesn't go...
helpful to know what kind of machine you have :\. In general one of the paper pickup roller pads is probably rotated 180 degrees out and not touching the paper, many rollers are triangular/square and have to be oriented correctly. Other causes are the plastic gears which if stripped means a junk printer unless its an expensive one. Stripped gears because someone pulled a jammed page out too violently is the usual cause. Check also for embedded staples/paperclips in the mechanism.
May 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Paper feed jams continually. I hear a repeated clicking sound at the time of each jam like the paper is trying to feed without success.
sounds like tthe first time it jammed power was on and someone pulled agains the tide forceing the removaly and stripping the transporter gears. Need to look inside and see if there is plastic gears looking stripped
Jul 29, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer is grinding
sounds Like a paper jam , Plus your paper feed rollers are dirty, clear any paper inside the printer, the using a cloth rag and some 409 cleaner , wipe feed rollers to remove white paper dust on rollers, and let dry, then add paper to printer and it should print.
Jul 21, 2009 | Office Equipment & Supplies
HP OfficeJet 6110 (4 years old) makes short grinding noises during printing. Occasionally the printer stops and asks to have the door opened and the jam cleared. The problem is gradually getting worse....
Try first to clean the encoder strip. It's the clear strip behind the printhead. Either use a Q-tip dampened slightly, or small towel. Don't apply too much pressure though, it can come off and they are hard to put back.
Jul 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Keeps saying no paper Makes loud clicking noise
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Jan 19, 2009 | Brother MFC-8660DN 5-in-1 Laser...
Lexmark 4270 won't feed paper to print or copy!
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Good Luck
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmarkx73 Won't feed paper through while printing
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
Paper feed malfunction
sounds like the item in the paper path that you can not see. or it has a faulty sheet feeder or some gears have failed in the printer
Sep 25, 2007 | Epson Stylus CX5800F All-In-One InkJet...
HP Photosmart 7850 InkJet Printer Logo
74 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
