Question about Garden
I had to replace the head gasket on my kohler 19 hours power motor model sv590 004. Now i can not find out what to torque the head bolts to the crank case. (How many lbs of torque on each bolt)if you can find this infomation or assemly instructions for this motor . thanks
  • 61 Answers
Manual says 30ft lbs starting from the middle
of the haed
Posted on Sep 06, 2009
Hi , can you tell me what is the torque settings for Main,biggens and head bolts for Opel combo 1.4 16v 2006 model z14xep motor?
STANDARD TYPE GM ROD BOLTS
STAGE 1---18 LB/FT (GRAPHITE GREASE UNDER HEAD, OIL THREADS)
STAGE 2---30 DEG's additional bolt head rotation.
CRANK BOLT
GRAPHITE GREASE UNDER HEAD & WASHER, OIL THREAD
STAGE 1---70 LB/FT
STAGE 3---15 DEG's additional bolt head rotation.
CYLINDER HEAD BOLTS for standard gaskets
GRAPHITE GREASE UNDER HEADS & WASHERS, OIL THREADS
SEE SEPARATE SHEET FOR TIGHTNING SEQUENCE
STAGE 1---18 LB/FT 25NM
STAGE 2---90 DEG's additional bolt head rotation.
STAGE 3---90 DEG's additional bolt head rotation.
STAGE 4---90 DEG's additional bolt head rotation.
STAGE 5---45 DEG's additional bolt head rotation.
Nov 06, 2016 | Opel Cars & Trucks
26hp kohler engine started smoking suddenly. still runs good.whaat would cause this problem.
Head gasket blown. This is a very common issue with these V twin Kohler engines. There is a kit you can order from Kohler that includes gaskets and new improved head bolts. Simple hand tools is all that is needed. You will need an inch pound torque wrench. Torque specs are included in the kit.
Jul 23, 2014 | Craftsman Garden
Why is my 2012 21hp sears 42" lawn tractor blowing smoke
If it is a V twin Kohler engine, you may have a blown head gasket. It is a common issue. Great engine but has this one issue. Kohler has a head gasket kit with improved head bolts. Torque specs are included. You will need a inch pound torque wrench and common hand tools.
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
We are replacing head gaskets on kohler command 25 68500,what are the torque specs for head and intake gaskets?
first torque to 16ft/lbs in a x patt. then 30ft/lbs in a x patt. for head the intake gaskets connecting to the head should be 12 to 17
Feb 02, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
NEED FORD 2.2l head gaskets torque chart
Tighten the head bolts 29 to 32 ft lbs , then tighten again to 59 to 64 ft lbs
Apr 17, 2010 | 1989 Ford Probe
Can you give me a ballpark figure on replacing a head gasket on a older Craftsman riding lawn mower...
there are many variables, since you didn't give any specifics. if it is an older, single cylinder, L-head engine, labor would be roughly 1/2 hour; if an older twin, L-head, about 1 hour; if it's a kohler, add about 1/2 hour; if it's a single, OHV, about 1 hour; if a twin OHV, 1 1/2 hours; if a kohler, add 1/2 hour. each shop has it's own labor rate. flat rate manuals will vary and are not realistic when dealing with old, possibly rusted or frozen bolts, which will increase the cost of repair. a new head gasket will usually cost between $5 to $30, depending on which engine you have. {some older craftsmans had a briggs laid sideways or an onan. these will require a lot more work and the labor would be higher]
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What is the head bolt torque on a 1990 suzuki lt250r quadracer changing head gasket had head resurfaced need to know the proper torque thank you just put in rm 250 no category for atv
The 8mm head bolts are torqued at 19 - 21 ft/lbs.
any smaller 6mm bolts are torqued to only 6 ft/lbs
like those on the lower cylinder.
Aug 20, 2009 | 2003 Suzuki RM 250
A 1981 GoldWing Interstate 1100cc. Started would
Check the compression before tearing it down - the cylinder with the water will probably come up low.
It's very likely that the head gasket has failed. As a result (or the cause) it's also likely that the head has warped, it'll need skimming before rebuilding the motor
Jul 31, 2009 | 1981 Honda GL 1100 Innerstate Gold Wing
I need torque specs.for head and centerhead when replacing new gaskets.
never have used a torque wrench to install toilet tanks. Put gasket on tank and insert bolts with rubbers washers through gasket and set tank on bowl in a level and straight postion and start nuts tightening them evenly until tank starts to snug to bowl. Hand tight is usually sufficient, you will see the rubber gasket and washers will compress to bowl and tank forming a seal (EVENLY) and tank will be firm to bowl. DO NOT superman torque these nuts! Compare the torque to finger strength on a wing nut. Hope this helps ,"if I understood the question."
Mar 22, 2009 | Kohler KOHGP51487 Authorized Original...
Garden Logo
376 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
