Question about V, Inc. Vizio P50HD Plasma Television
Turn on TV no sound and video screen stays black
I have Vizio P50HDM TV When I return it on I here a clicking sound and I believe the light goes green a few seconds later theres nother clicking sound I believe it comes from another are and the light flashes orange (I believe it goes to safe mode). The TV is about 3 years old and I had a Sears service guy come out he did not seem to know much but said it maybe the Plasma screen or the display board part #6870QZH044B. He did this without even removing the back of the TV. He then informed me the TV Display card was no available and the TV was scrap. But when I went on e-bay I saw the the card. Do you what maybe causing the problem.Puzzled
  • hamish514 Jun 20, 2009
    I tried shuting of the power for severals days but no change. Is there a place I can send the card to have it checked out. I have no faith that the service guy at sears know what he is doing. I had to ask him to pull the back of the TV off.
    President:
  • 632 Answers
It really goes to safe mode to prevent further damage..it happens when the systems detects a fault during start up..it's really hard to point out the exact fault without visual inspection and actual test and inspection of parts..it could just be a point size solder or dirt stucked between the pins of an IC or a resistor loose solder..professional service is suggested..
Posted on Jun 21, 2009
    Sergeant:
  • 296 Answers
Hi
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
regards
Posted on Jun 20, 2009
Vizio P50HDM Plasma
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 23, 2014 | Vizio 50" p50hdm high definition...
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hi, I have a Vizio P50HDM
For your Zenith P42W34D TV. The problem cause the a bad Y drive board. Replace the board will fix it.
Hope this will help.
Jan 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Another dead Vizio... P50HDM
95% Y and Z sustainer boards since you alweady had red pixels.
May 15, 2008 | V, Inc. Vizio P50HD Plasma Television
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Vizio 50" P50hdm Audio with No Video
when tv is on horz trans is damge
Apr 10, 2008 | Televison & Video
On and off and on again
You have a power supply problem, it is in standby . Replace powersupply board or fix it.
Nov 26, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
V, Inc. Vizio P50HD Plasma Television Logo
65 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
