Question about Sony Playstation 3 (PS3) Console
Do you want to output video and audio using HDMI on the PS3?
When i turn my PS3 on, something comes up that says an available HDMI device was detected. Do you want to output video and audio using HDMI? And when I press either one, i lose video. I can still hear, but the picture is gone. No video, only audio.
    Problem Solver:
  • 5 Answers
How do you have the PS3 hooked to your tv?
Posted on Jun 20, 2009
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I have the phillips system. i didnt get a manual with mine. so im hooking it up with out one. ok i have a cable running off of my hdmi cable and ps3 on hdmi. i took my ps3 off and pluged the blueray up to...
I don't recommend doing things without a manual when one is available...
http://www.p4c.philips.com/files/h/hts5580w_f7/hts5580w_f7_dfu_aen.pdf
Think about where you TV audio originates. Unless you have an antenna on your TV, everything IT hears comes from an external audio device like a cable/sat box which almost certainly has a digital audio output and/or HDMI.
I would recommend you carefully utilize your limited connections this way:
Using Page 10 as a guide.
IF your TV has 2 HDMI's or one HDMI AND one Component input:
Cable box (Component Out and Analog Stereo RCA) or HDMI Out to corresponding TV In's if available.
Cable Box coaxial audio to the HTS (3). This way the best broadcast TV multichannel audio goes to the best electronics and speakers.
HTS HDMI Out (9) to TV Component In (if available), otherwise use Component Out (7). I recommend saving the highest quality video delivery path for your native BD because broadcast Hi-Def video is always bandwidth compromised while BD is the best video available today.
Composite Video Out (6) to Composite Video In on TV for HTS management functions.
You still have both Aux In (4) pairs).
Jan 25, 2011 | Philips HTS5580W/F7 Theater System
How to format so ps3 works
If it's one of the original PS3's you can hold the power button down when you're powering it up until it beeps and then let go of the power button. This will make the PS3 search for what video devices are plugged in. If you're using the HDMI it will say "An available HDMI device was detected. Do you want to output video and audio using HDMI?", and you wan to say YES. Then it will automatically set the resolution (should set to 1080i) and give you 30 seconds to confirm the video works by saying YES again. This TV will not support a 1080p output so if you try to change the PS3 to 1080p resolution it will not work.
Dec 27, 2010 | Sylvania LC320SLX 32 in. LCD TV
FORMAT NOT SUPPORTED FOR PS3
If it's one of the original PS3's (might be the same for the new) you can hold the power button down when you're powering it up until it beeps and then let go of the power button. This will make the PS3 search for what video devices are plugged in. If you're using the HDMI it will say "An available HDMI device was detected. Do you want to output video and audio using HDMI?", and you wan to say YES. Then it will automatically set the resolution (should set to 1080i) and give you 30 seconds to confirm the video works by saying YES again. This TV will not support a 1080p output so if you try to change the PS3 to 1080p resolution it will not work.
Dec 20, 2010 | Sylvania LC320SLX 32 in. LCD TV
Sylvania tv says format not supported when ps3 is plugged into it, just happened use to work fine
I have also received this message when I had a bad HDMI cable.
Nov 29, 2010 | Sylvania LC320SLX 32 in. LCD TV
Sound issues with HDMI connection.
manape7
It depends on the device that you are connecting to the HDMI Cable to. Some devices like LCD monitors are not designed to pull audio from the HDMI channel. In those cases you will need to use the Optical or Analog audio output. Note when you do this you wil need to change the settings in the audio setting option to select those outputs.
Let me know if you have any problems or questions
Issken
http://www.fixya.com/users/issken
May 30, 2010 | Sony Playstation 3 (PS3) Console
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Incompatible video signal check the output device setting playstation 3
remember that most dvd/surround sound systems do not support picture mode through some inputs (just audio), you should check your manual as it is usually in the small print.
May 01, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
797 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
