Question about JVC Audio Players & Recorders
JVC Turntable won't turn, motor works, can't remove platter
I just bought a turntable at a garage sale this weekend (JVC JL-A20) and I plugged it in and turned it on, and it will not spin when I move the arm over the platter. When I remove the mat and look inside one of the openings of the platter (while plugged in and the arm is over it) I can see a copper looking round thing which is what I believe is the motor, and its spinning and will stop when the arm is placed in its original location. I try removing the platter by simply pulling up on it, however it won't come out. Do you think the only problem is getting the motor to turn the gears? And if so (and if I need to replace the belt), how can I do that and how can I remove the platter? Thanks for your help!
    President:
  • 1,126 Answers
Http://www.vinylengine.com/library/jvc/jl-a20.shtml
Looks like this is a belt drive model.
http://www.turntablebasics.com/belts/jvc.html
This site claims to provide installation instructions with belt purchase. Good Luck.
Posted on Jun 23, 2009
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    I have a jvc jl-a20 auto return turntable and the arm briefly returns then proceeds to travel across the album. What do I have to do to get it to stay at home after it returns? Thank you
    It's probably some kind of mechanical problem. Perhaps something bent out of place.
    I have found a photo which is the underside of the model. You can compare it with yours and see if it looks the same. If it doesn't (assuming it is the same model) then you have found the problem.
    http://www.vinylengine.com/turntable_forum/gallery/image.php?mode=large&image_id=30141
    Oct 12, 2015 | JVC Audio Players & Recorders
    My turntable turns and the arm moves onto the record but then the arm moves back and the turntable shuts off. What's wrong?
    The auto reject/auto return lever has been advanced therebt tripping the arm to return to the pick up rest.It needs adjustment.
    Jul 13, 2014 | Denon Audio Players & Recorders
    Platter not spinning
    Some turntables only move when you move the arm to the record. If that doesn't work and you have read the set up instructions correctly, as it's new contact the maker or the place you purchased it from. I'm certain they will help.
    Mar 22, 2014 | Califone International Audio Players &...
    AL-A1 turntable won t turn
    take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
    Jan 19, 2014 | JVC Audio Players & Recorders
    JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
    Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
    Nov 23, 2013 | Audio Players & Recorders
    Power is on, turntable won't turn
    Hi, sounds like the belt was not refitted when the motor was replaced.
    To replace drive belt on a Crosley turntable.
    1. Remove the cir-clip holding the platter in place from the base of the centre spindle.
    2. Lift the platter off. You may need to use a flat blade or some similar tool to get under the platter in order to lift it up.
    3. NA.
    4. Place the belt around the platter pulley making sure it is sitting flat without any twists.
    5. Flip platter over the right way up
    6. You will see 3 rubber grommets in the platter surface. Remove 1. Through the hole insert a belt hook, crochet hook, kebab skewer, knitting needle type tool and slip it
    between the platter pulley and belt in readiness to fit over the motor pulley.
    Nov 15, 2011 | Crosley CR249TA Turntable
    Need to replace the belt on my JVC AL-A95 turntable
    To replacea turntable drive belt.Copyright.. Styluscity.com, JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
    2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
    3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
    4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
    5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
    6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
    7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
    8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
    9. Replace the rubber mat and then run the turntable to ensure correctoperation.
    MUSIC IS LIFE, LIVE IT LOUD.Styluscity.com cansupply replacement drive belts for all turntables
    Oct 08, 2011 | JVC AL A158BK Turntable
    1,187 people viewed this question
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
