Question about Insignia LCDTV26 26 in. Television
Insignia TV/DVD combo, HDMI cable, no audio on non-HD channels
Same problem. Changed the cable box and cable, no difference. Same cable box and cables work fine on my Samsung HDTV. Geek Squad insist it is NOT the TV. Go figure. I bought insurance on the TV and will keep fighting with best buy to get it replaced. Any ideas?
by the way, yes I did change the audio on the cable box to HDMI. I have Time Warner cable and the cable tech spent two hours trying to figure out the problem but couldn't.
3 Suggested Answers
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
alpug
  • 1961 Answers
SOURCE: Insignia IS LCDTV32 Will not power up.
Convert it. Use alternative WEIYA power supply with 5V, 12V and 24V output. 24 volts is for the backlight, the 5 volts is for the main computer board and the 12 volts for the sound card.
Posted on May 17, 2010
Hi, I am in Melbourne Australia. Can I receive gem hd channel thru my dmr-ez48v. I haven't tried but I do have a hd monitor screen that I can plug the unit into. Also what does the hdmi on the unit do....
HDMI means high definition multimedia interface.
When connected to an HDMI compatible unit, an uncompressed digital audio and video signal is transmitted, enabling you to enjoy high quality digital video and audio with just one cable. When connecting to an HDMIcompatible HDTV, the output can be switched to 1080p, 1080i or 720p HD video.
Panasonic uses Viera link option between their video products.
When connecting with a Panasonic TV (VIERA) or a receiver equipped with 'HDAVI Control' function, linked operations are possible. [Linked Operations with the TV (VIERA LinkTM HDAVI ControlTM)]
Please use HIGH SPEED HDMI cables that have the HDMI logo (as shown on the cover).
It is recommended that you use Panasonic's HDMI cable.
Recommended part number: RP-CDHG10 (1.0 m/3.3 ft.), RP-CDHG15 (1.5 m/4.9 ft.), RP-CDHG20
(2.0 m/6.6 ft.), RP-CDHG30 (3.0 m/9.8 ft.), RP-CDHG50 (5.0 m/16.4 ft.), etc.
Non-HDMI-compliant cables cannot be used.
(the above is from the owner's manual of this model - page 40 tells you about linked operation using HDMI HDAVI control and how to set it up)
As for Gem HD, this unit has an SD (standard definition) digital tuner - it will not decode/receive HD channels. I should point out that 7mate also is a HD channel but is not specified as such in any menu or even their website. (I found this out by accident when I tried to record on timer 7mate one day and all I got was 'unable to decode HD channel' banner at the bottom of a blank screen)
Channel 11 is a SD channel - so this will work with your DMR-EZ48 as will all the other relevant main free to air channels (ABC/7/9/10/SBS). GO! is also a SD channel.
To be able to record HD to this combo unit you will need a HD set top box connected via its AV inputs. HDMI simply means you will get HD video quality from the combo to the TV, you will not receive HD channels from your HDTV to your DMR-EZ48 unit via this method.
Mar 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I connected my HDMI cable to my television and have comcast for my provider. I get the HD Channels beautifully but when I go to a regular non HD channel, I get no sound at all, only the picture. How am...
You will need to used a red and white cable that will connect to the (audio out) on the comcast box and then to your (in audio) on your tv.
Thanks
wbigtodd
Jan 22, 2011 | Insignia Televison & Video
I am trying to setup my receiver with my TV and Comcast cable box using HDMI cables (TV-OUT and HDMI-1) but for some reason I don't get any sound from non-HD channels. Am I missing something?? I've read...
I'm thinking there might be a setting in the cable box that may be sending the wrong bit rate for PCM 2-channel audio but usually the receiver decodes that stuff fine. Just the same, I'd give Comcast a call.
I run the video from my cable box directly to the TV (HDMI) and the coaxial digital audio to my receiver so each one can do what it does best with the best possible un-modified source data.
Dec 25, 2010 | Sony STRDH810
I have a DVD1001 DVD VCR combo how do I hook DVD combo to my tv
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
Dec 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
May 31, 2009 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
In a nutshell, there is no solution to this problem. The new Insignia TVs have a compatibilty issue with certain HDMI connections. The best thing is to return the TV and purchase another brand. I bought the LG w/built-in DVD and everything works great.
Feb 05, 2009 | Insignia LCDTV26 26 in. Television
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Insignia LCDTV26 26 in. Television Logo
742 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
