I turn on my washer machine it runs but at some point it turns off and i have to open the lid and slam it back down for it to turn back on
    President:
  • 1,136 Answers
Hi, You will need to change the lid switch. It is going bad.
If you will get me a model#, I can get you part# and instruction on changing it.
Vic
Posted on Jun 20, 2009
    President:
  • 1,564 Answers
The sensing switch for the lid has depressed from it's original location. Try to wrap a small amount of electrical tape to the end of the pin that goes into the small opening in the right rear. If this does not work, your machine will have to be turned on its side and the connector deep in by the top should be pushed on harder, Unplug it first and stop slamming, that solves nothing.
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Well, it seems my kenmore series 70 washer model 110 92274100. wont spin or drain. I did slam the lid down, i am kinda rough on appliances.anyhow, im assuming the safety latch is bad now. I had a load in...
:) ok do this,,unplug the machine .. pop the lid up, not the door , the whole lid,, you will see where the safety switch is,, this is just a pass through switch and can either be jumpered or by passed to check them, locate the plug connection for the switch ,, use a wire to make a U shape and push one end of each end into the connector ( one in each side,, make sure that the 2 wires don't touch,, ) and remember to do this to the side of the machine, Not the part that goes back to the switch,, then plug the machine back in, and set it to the spin cycle,, if this works, just replace the switch
Aug 25, 2011 | Washing Machines
My washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Jul 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
Kenmore washer will not go to rinse cycle. 70 series
I had the same problem and it was a broken switch that prevents the washing machine from going into spin with the the top door open. The switch is located in the upper left corner, you can see 2 screws that hold it in. Reach under and check that the middle point when pressed pulls the ends where the actual switch is, you should hear a click.
I was able to temporarly repair by focing the swtich to always be depressed with 2 strips of duct tape. - Warning the washer will go into spin cycle with the top open.
Jan 04, 2009 | Kenmore 22422 Top Load Washer
Have to slam lid down to get washer to start
Did not want to disect the entire machine to get at the lid switch. Couldn't figure out how to get the corner covers off so I figured we would continue to slam the lid until that no longer worked and then "call the guy". Thanks.
Jul 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Have to slam the lid
The same thing happened here. It turned out to be the lid switch. It can be accessed by taking off the back plate (behind the controls) by unscrewing three screws and two screw bolts -simple.
I removed the lid switch and tested it with an ohm meter - instructions are on this site. You should have continuity across machine-motor, as well as across machine -line. (These are labeled on the switch).
If you don't have a meter and you still want to see if that's the problem, after you have removed the lid switch, short the machine and line connectors, (you'll see these labeled on the lid switch so you'll be able to figure out which wires go with what) as well as shorting the machine and motor connectors. Both of these need to be shorted. That bypasses the switch and will activate the motor and controls.
That's what I did to confirm that it was all a "lid switch " problem. I ordered a lid switch from this site for $24.95 for the repair, and will use the "shorting process" to do a couple of loads of wash as I wait three days to get the switch. Good luck.
Dec 16, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
