There is no clear cmos password jumper located there.. is there any other options
SOURCE: toshiba A135-S4527 cmos battery dead
I found where the cmos battery is located. By the Toshiba tech support website , it's next to the PCMCIA Slot, just behind it. To get to it, Take off LCD, keyboard, top palmrest, hard drive, battery, memory, top power cover,switch board, modem, network. and some others. Too many to describe here. Items to remove not in order.
I Have the service manual downloaded already.
Let me Know
comier957
SOURCE: toshiba satilite a215 s7422 bios password how to cleare
You'll need a special tool that only Toshiba has. I believe you can get yours cleared for FREE if you tell them that all of a sudden out of nowhere you have a bios password. Stick to that story because they've already admitted to the problem with many of their laptops. You'll have to find an authorized Toshiba repair center to take care of it for you. Otherwise I believe they charge around $100 to clear it.
Don't bother to try the cmos battery trick, it doesn't work on your model. The password is stored on an onboard chip.
SOURCE: Cmos / Bios password
IF IT COMES TO A SCREEN THAT SAYS "TOSHIBA" AND AT THR BOTOM LEFT SAYS ''F2-UTIITY , F12- BOOT MENU'' CLICK F2 IMIDITLY AND USING THE RIGHT CONTROL BUTTON SCROLL TO ''SECURTY'' AND CHANCE THE PASS WORS
SOURCE: Trying to locate the cmos battery for Toshiba Satellite L25-S121 laptop?
On the Toshiba Satellite L25 S1217 Laptop, the battery is indeed to the left of the wifi card. I was having a problem with a bios password and had spent a considerable amount of time looking. However Instead of taking the whole laptop apart, I removed the wireless card and used a precision flathead to maneuver the connector out of it's socket. after a few seconds I booted the laptop, with the battery still disconnected , and no password prompt! using the same screw driver, I was able to get the connector back into it's socket, and put the wireless card back in. it runs fine now. the trick is to only pull the connector out only enough so that it's not making the connection, if you pull it too far you will have a tougher time guiding it back into the socket. I hope this helps a lot of people with the same problem.
SOURCE: How to remove the cmos or bios password and want
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Once this jumper has been changed, turn on the computer
and the password should be cleared. Once cleared, turn the computer off
and return the jumper or dipswitch to its original position.
The location of the jumpers or dipswitches are dependent on the
manufacturer of the computer and motherboard. However, below are some general
ideas on where to find it. Remember that most motherboards could have dozens of
different jumpers, make sure you're changing the CMOS jumper and not something
else. If these general suggestions do not help refer to your motherboard /
computer documentation or skip to the next step.
