Question about Epson Perfection 1240U Flatbed Scanner
Scanner not working - get error message
Scanner fails to scan.
Once warm up is done, I get this message...
Scanner not ready. Check that the scanner is on.
Help needed bad
  • jackmid Nov 07, 2007
    Have same problem although it is intermittent. Scanner previews OK, but then gives above-mentioned message when "scan" is invoked. Think it is a weak scanner lamp.
  • 526 Answers
First, check to see if the bulb lights up, if not you have bad bulb. the bulb can be ordered separately. if the bulb is good, you have a problem with the main board.
Posted on Dec 20, 2009
My Ambir ImageScan Pro 820i will start scanning then stop half way and say "scan (not responding)" then error message "generic error"
To help you troubleshoot the issue about unable to scan the document 100%, please follow the steps given below:
- First of all check whether power connection and cable connection to the scanner are correctly connected and it must not be loosen from any end.
- Check if there are any updates available for scanner software to be installed. If yes, then install the updates and restart the computer and scanner once for ready to scan.
If issue persists, it is recommended to contact 'Ambir Support Center' for further assistance from the link given below:
Jun 25, 2016 | Ambir Technology Ds820-as -imagescan Pro...
Scanner not scanning
Helen, I feel that the scanner part of the SW has gone corrupt for whatever reason. You must first uninstall the scanner from Control Panel. The reboot the PC and reinstall the scanner. Once done then only you must connect the scanner to the PC. Now allow some time for the Windows to detect the scanner and load its drivers. And when you get a message in the right bottom corner of the screen saying "Your new HW has been installed and is ready for use", you can start scanning documents either from specific program for it or from the word processor. Hope it works for you.
Dec 04, 2009 | HP Office Equipment & Supplies
My scanner fails to scan documents. It either generates a "warming-up" message OR "sorry, scanner could not be initialized. (Scanner parameter error.)" message.
there are many users facing this same error message.
there are options to solve the issue.the upper part of the printer is have to remove that upper portion by removing the screws and internal locks on its inner layer.then check out if any dust is got collected on the scanner lens.the lens is a thin glass layer in the scanner that reads the document which you place on the glass.if the dust gets collected on the lens it will show this error messages.but if after cleaning it shows same message that means the internal board is got faulty.there is a mini circuit board beside the scanner the upper scanner assembly needs the scanner assembly set you get the new circuit board.scanner assembly means not the upper scanner glass it only includes the inner assembly and the circuit board of scanner assembly.the cost of new assembly is near to $ can get this assembly at any local printer repair shop.they have it in spare or they can easily get it from nearest service center of the hp company.
Nov 20, 2009 | HP PSC 950 All-In-One InkJet Printer
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link :
Jan 13, 2009 | Office Equipment & Supplies
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
I Want Mercury Scanner 620P windows xp Driver
Aug 16, 2007 | AcerScan 620PT Flatbed Scanner
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
Epson Perfection 1240U Flatbed Scanner Logo
292 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
