Question about Sony Playstation 3 (PS3) Console
I got an error message saying my hard disc file system is corrupt press ps and x to fix and it would get to 100% restart and go throught the same thing over and over again. I had a look at it again today and now it is saying there is no system information updates, update version higher that 2.42 but I cant get to the menu page or safe mode, can someone help me get to the menu page or safe mode please???
  • 2,335 Answers
I can help you get your PS3 into Safe mode.
Just follow the steps I've types out in this PS3 Safe Mode Tip.
I hope that helps.
____________________________________
Sony PS3 Safe Mode
Posted on May 08, 2010
Hard disk cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 it says, hard disc corrupted and will be restored. I click yes the bar goes 100% and the same message cames again. can you help me please
with your console off, hold power button down until it turns on, it will beep and while still holding it in a few seconds will beep again. connect your controller, press ps button and it should bring you to a screen with 6 options. Chose number 5 this will reformat your corrupt drive so you can operate your system. However it will wipe your memory off the drive and you'll have to start from scratch. This is the only way to fix this problem at this point.
Jan 22, 2011 | Sony Video Game Consoles & Games
Playstation 3 message "hard disc file system is corrupted..."
Your hard drive may have gone bad. Maybe try using a different hard drive. Once you put it in, the system data should install itself.
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Error message that says boot disc error. there is
This is either a corrupt file system or a bad hard drive. You'll need to boot from a Rescue CD like BartPE or a Windows CD and run chkdsk on the drive to see if the file system has just become corrupt. If that fails, you may need to run "fixboot" and "fixmbr" from the recovery console. If those fail, or if chkdsk comes back and says it can't repair the damage, then you probably need a new hard drive.
Mar 19, 2010 | Acer Aspire™ T180 PC Desktop
File system error: FAT is corrupted
Your hard disk on your media player is corrupted which also does happen on a normal PC/Laptop. To fix it, use windows explorer -> right click on your mouse againt the media player drive -> select properties -> select 'Tools' tab -> select Error checking / Check now -> Tick on 'automatically fix file system errors and recommended also 'scan for and attempt recovery of bad sectors' -> Start.
At this point, you may also need to restart your PC/LAPTOP and then be patient as 120GB is a fairly large drive to repair! Once the FAT has been repaired, depending on the corruptions, you may need to replace some songs, video, photos or other files.
ps. the other 'drastic' option is of course to reformat the whole Media driver drive !!!
Dec 18, 2009 | Archos 5 MP3 Player
Error message that says the hard disk's file system is corrupted
tlatrice_66
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
THE HARD DISK'S FILE SYSTEM IS CORRUPTED AND WILL BE RESTORED
hold in the power button until you hear 2 beeps. might not work the first time. if no 2 beeps repeat power button again or until 2 beeps. go to restore hard disc and click on it. you will lose anything saved on the hard disc but fixes it 75% of the time. did it myself this morning.
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
I start up my computer, I get a black screen that says press F1, after I do that I get a black screen with a message that reads, operating system not functioning
Have you take note the error message about the operating system? does it say a corrupted windows file?
With regard to the error message about F1 to continue, i would say that your hard drive is looking for the operating system. There is a possibility that your operating system is corrupted due a virus infected file or a system file was accidentally deleted from your computer or it could be an issue with your hard drive itself.
You may need to check also if your hard drive is detected by computer. You may call your computer manufacturer if your system still under warranty. In case the hard drive need to be replaced.
I suggesst to run a system diagnostics first to check if the hard drive still functioning before you run windows repair using the operating disc you have with your system.
Keep me posted.
Oct 12, 2008 | HP Computers & Internet
Hard disc file corrupted-how do you repair?
you need a new hard drive. this will void your warranty but you can replace your original hard drive with another one of the same type (IDE / SATA) and all you should have to do is pop in the drive and it will ask to reformat the drive, say yes and let it go. then you can start playing your games again. if that dosn't work then your firmware is corrupt/damaged and you will need a new ps3. just take the hard disk out and use it in your computer or sell it on ebay. other than that, keep the busted ps3 for spare parts in case the 'new' one needs a new bluray drive in the somewhat near future.
Aug 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
87 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
