Question about IBM ThinkPad T40 2373 Notebook
IBM Thinkpad won't get bright. F button doesn't do anything
I can't get the screen to get brigthter. It is dimi. F1 + Home does not make it brigher.
Help.
  • 674 Answers
Adjust screen brightness
go to start-->control panel--->display--->adjust brightness
i need to know what operating system you use this will work for only Vista and 7 and 8 and 8.1
Oct 10, 2014 | IBM ThinkPad T40 2373 Notebook
Screen is blank when the computer is turned on
The IBM ThinkPad is a brand of laptop computer developed by IBM. In 2005, Lenovo bought out IBM's laptop division. ThinkPads are like most laptops in that their screens are one of their most delicate features. If a screen is exhibiting problems, knowing how to troubleshoot the issue can save you a headful of worries and get you to the source of the problem.
No Video If you are experiencing no video from your display, make sure the laptop is powered on. The ThinkPad has a power status indicator on the body and will be illuminated if the computer is turned on. Once you verify that there is power, check that the laptop is not in sleep mode by holding down the "Fn" key for 10 seconds. If you are not in sleep mode, try to toggle the ThinkPad between external display and internal display mode. You can do this by pressing down the "Fn" button with the "F7" key. b> Verify Working Internal Display If you are not receiving any video when your computer is on, there is still a chance it could be a software issue. Turn off your computer. On the ThinkPad A, G, R, T, X and Z series computers, you can boot up in a basic level of the computers operation called BIOS to verify that the screen works. When you restart the computer, press and hold the button according to your model to turn on BIOS. This will either be "Press F1 for BIOS Setup Utility," "To interrupt normal startup, press the blue Access IBM button," or "To interrupt normal startup, press the blue ThinkVantage button." You can find out how to access BIOS for your particular ThinkPad model by referring to your owner's manual. Removing the Screen If you have a picture on your screen, but it is faint as a result of lack of light, adjust your brightness settings by holding down the "Fn" key as well as the "Home" button. If you do not get an adjustment in brightness, you may have a faulty backlight or inverter. If it is the backlight of the screen, you may need to change the inverter board. This is a small circuit board that controls the brightness of your LCD. If your computer is under warranty, take it in to Lenovo and have it repaired. If it is not under warranty, you can attempt to take it out yourself by removing the screen. For this job, you will need a screwdriver as well as a knife. Remove the screws around the screen housing and remove the small plastic covers with your knife to get at hidden screws. Use your knife to pry off the front bezel of the screen. The bezel is a plastic piece that frames your LCD. Remove any screws from around the LCD screen to remove it. At this time, you can replace the inverter board, the LCD panel or the LVDS cable--the low-voltage differential signaling cable that that sends graphics from your computer's graphics card to your screen.
Feb 26, 2013 | IBM ThinkPad T60 Notebook
The monitor screen is not bright enough to read information can I brighten or enhance? Is there a function key on the keyboard that will allow this?
Try holding the function key & tapping the Home button on keyboard:
Fn + Home - The computer display becomes brighter.
If this doesn't get it bright enough then perhaps the LCD backlight is dying. Easier to replace the whole screen than just the light.
Good luck.
Feb 20, 2013 | IBM ThinkPad Computers & Internet
Bad home key on thinkpad g41 keyboard is there an alternate way to increase brightness?
Try using Thinkvantage Application to adjust as follows:
ThinkVantage Control for Display Brightness
  • 4 Click the "Start Menu," then click "All Programs" and locate the "Access IBM" program group.
  • 5 Click "Thinkpad Configuration" and click "LCD" to open the brightness control dialog. Select the brightness from the drop-down menu and click "OK."
  • 6 Click the red "Exit" button in the upper-right corner of the Configuration utility to close it.
Read more: How to Adjust the Brightness on an IBM ThinkPad Display ' eHow.com http://www.ehow.com/how_5818403_adjust-brightness-ibm-thinkpad-display.html#ixzz277iQ4g48
Sep 11, 2012 | IBM ThinkPad G41 Notebook
IBM Thinkpad T30 2366 won't boot after the IBM Thinkpad screen
you can go to the BIOS setting? if you can,look for "Boot Device Priority" or something like that,it's usually placed on Advanced settings. Set the first boot device as your harddisk,save the settings and restart your computer
Please let me know if it's working or not
Aug 28, 2012 | IBM ThinkPad T30 2366 Notebook
When booting up the screen displays FAN ERROR
Is the fun running? you can first confirm that before you alter anything in the Bios. touch on the fun air exit point you will feel it if its running.
Regards
May 05, 2010 | IBM ThinkPad T30 2366 Notebook
I have a very old IBM thinkpad laptop and the srceen is very dull
go into your bios at start up press f2,del or f8 and you'll see some kind of brightness control pretty sure but their is several thinkpads
Mar 02, 2010 | IBM ThinkPad 600X Notebook
How do you lighten the screen on the ibm a20m laptop computer?
Hello sandee232,
The following key combinations can be used for screen brightness:
•Fn + PgUp Turn the ThinkLight on or off.
•Fn + Home The LCD becomes brighter.
•Fn + End The LCD becomes less bright.
The screen brightness information can be located inthe IBM ThinkPad A21m User guide:
http://safemanuals.com/314159.php?k=c7c8bab9c3a5ec3c048ad8dc9eb006be&ID=321133&q=IBM%20THINKPAD%20A21M
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad R51-monitor too bright
Pressing the Fn/Home buttons should increase the brightness, while Fn/End should decrease it. Hope it helps.
Feb 21, 2009 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
67 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
